New setup to beat my brothers 08' ZO6
Old Nov 26, 2009 | 11:10 PM
javicracer's Avatar
Originally Posted by mak1000
bump.....anybody else. What do you guys typically think about the GT35R turbo...i've heard mixed stuff.
too laggy for my taste
Old Nov 26, 2009 | 11:31 PM
GdotRegEvo9's Avatar
i would get Kelfords 272s all the way and sum meth and you will be good to go
Old Nov 26, 2009 | 11:45 PM
javicracer's Avatar
+1
easy and cheap setup!
Old Nov 27, 2009 | 05:24 AM
RyuEvoIX's Avatar
You could have given him a good run on the stock turbo if all your concerned about is trying to beat him. There's plenty of guys around the country this year running mid to low 11's on the stock turbo list. Personally I think the 35R is outdated technology. You should be able to take him on pump gas as long as you can drive the car. Won't be as fun though on the street.
Old Nov 27, 2009 | 05:51 AM
vaboostn33's Avatar
you could be him with a stock turbo and cams if hes only running 11.5. He cant drive for ****.
Old Nov 27, 2009 | 06:47 AM
X_Evo's Avatar
You are still on the stock block correct? Personally, I would not push the limits of the 35 on a stock block with E-85. I'm not sure why I see a continuing trend of individuals installer bigger turbos into cars and keeping the stock cams...it just doesn't make sense.
Old Nov 27, 2009 | 08:05 AM
fre's Avatar
fre
Well I run a similar setup, plain 35R .63 ar exhaust, 32psi, e85, 272 hks cams, AEM, a walbro 255, inline bosche 044, 1150cc injectors and the time/trap in my sig (11.140 @ 131.82).
You will need a good tune. I have run everything from 12.4 @ 116 to what I run now with the only difference being the tune/AEM. You might also want to get an AEM. I was able to hit 11.6 @ 123 on the stock ecu and I am sure with the new stuff out now you can probably better that, but AEM will definitely get the most out of your setup.
If you guys go to insane speeds, he will still get you because of aero/gearing, so try to keep it below 160 or so
Old Nov 27, 2009 | 08:08 AM
dubbleugly01's Avatar
Originally Posted by fre
Well I run a similar setup, plain 35R .63 ar exhaust, 32psi, e85, 272 hks cams, a walbro 255, inline bosche 044, 1150cc injectors and the time/trap in my sig (11.140 @ 131.82).
You will need a good tune. I have run everything from 12.4 @ 116 to what I run now with the only difference being the tune.
a single walbro is enough for that setup?
Old Nov 27, 2009 | 08:14 AM
fre's Avatar
fre
No, read again, I have an inline bosche 044. Don't get the inline walbro, it sux (burned though 2 of them and they don't flow as well). If I build my engine I will need to go with a Y parallel setup instead of an inline series setup and probably bigger injectors as I am already maxed out at about 550-560whp on this setup with e85.
Old Nov 27, 2009 | 10:51 AM
mak1000's Avatar
thanks for all the advise. what is the difference between the HTA35 and the GT35r?? which one is better for use with the stock block? where could i go to get more info on the HTA35? I would still have time to get the HTA35 if its better?
Old Nov 27, 2009 | 11:40 AM
X_Evo's Avatar
HTA35 is argueably one of the best street turbos out there when matched with a built 2.3. I believe the wheel is *slightly* smaller or the same as a 35r, but it spools sooner then a GT35R, although it seems to make about the same top end power. Here is a link, albeit an old one, of Mellon reviewing the HTA35 https://www.evolutionm.net/forums/se...-reviewed.html
Old Nov 27, 2009 | 11:48 AM
smoke777x's Avatar
That set up should destroy that car. I ran 11.5 on stock turbo, TBE, fuel pump, FMIC and IC pipes, still on stock everything else.. You just need to know how to drive your car IMO.
Old Nov 27, 2009 | 12:19 PM
G20's Avatar
G20
11.5 / 125mph is a good number and you'll need at least 500whp and good shifting to consistently beat him. With my RNR gt35r on my 03, I was able to trap up to 127mph but due to my clutch locking out and below average shifting, I was only managed the best of 11.8. I was pushing 530 whp/C16 on dynojet at the time.
Old Nov 27, 2009 | 12:26 PM
JohnBradley's Avatar
11.5 can be done with 400whp and some driving. If its only going to be on the track it doesnt take more than 460whp to match a vette at 460whp. Luke has run 11.22@124 at 430whp. I have trapped 123 at 425-435whp and some lousy shifting.
Old Nov 27, 2009 | 12:28 PM
Rez90's Avatar
Good luck. If you're running straight pump gas and no cams.........i still think he'll take you.
Just my opinion.
