IX MR drain plug question
Old Nov 30, 2009 | 09:55 AM
SyZyGy1394's Avatar
IX MR drain plug relocation question
Anyone know if its possible to fit some kind of adapter to the drain plug with the temperature sensor so you can plug it into one of the ports on the oil filter housing? What sparked my curiosity was that I was thinking of running a magnetic drain plug, and maybe putting the stock drain plug with the temp sensor in the oil filter housing and having the MR oil temp gauge still work.
Anyone?
Old Nov 30, 2009 | 10:03 AM
thedru13's Avatar
I am not sure. I ditched the OEM set up. Kinda baffled me when i saw that is where they decided to tap into. I plugged into one of the screw holes by the oil filter housing.
Old Nov 30, 2009 | 10:20 AM
SyZyGy1394's Avatar
Hmm... I still want to keep the gauges for now, even though I may ditch them later. If there is no adapter that I can use, maybe I can get one machined from brass? Anyone know the exact thread specs on the MR drain plug and the specs on the port I should be using on the oil filter housing? Btw, which port should I use?
Or am I wasting my time because magnetic drain plugs for the engine are a waste? I've got no experience with them, so I'll search a bit about them to see if they are effective so I'm not wasting my time on thinking of doing this little change.
Old Nov 30, 2009 | 11:02 AM
dancarroll0283's Avatar
I know the oil temp sensor that Defi makes will work with the stock oil temp guage. Get ahold of them, and use the wiring in the car from the stock temp sensor...
Old Nov 30, 2009 | 11:28 AM
SyZyGy1394's Avatar
I may go that route, but I'd really like to know if I could just use an adapter, that is if one exists. Mainly because it would be a lil cheaper IMO.
Old Nov 30, 2009 | 04:17 PM
blkmkIII's Avatar
try and tap it hard... i did it to mine.. started to work.works every few weeks. my boost gauge is also off.
Old Nov 30, 2009 | 04:26 PM
SyZyGy1394's Avatar
All three of mine work fine.
I am just thinking about relocating the drain plug, which has the oil temp sensor in it, to the oil filter housing somehow and then run a magnetic drain plug.
Old Nov 30, 2009 | 05:52 PM
thedru13's Avatar
More trouble than its worth if you ask me..
Old Dec 1, 2009 | 07:18 AM
Your better off getting the defi sensor.
DanielM
Aug 6, 2016 07:08 PM
ak47po
33
Mar 21, 2016 11:31 AM
DangerDave4G63
Feb 8, 2014 09:01 PM
EvoIXMR
Nov 25, 2008 05:59 PM
BADEVO
Nov 23, 2004 01:26 PM
