Turning boost down?
Turning boost down?
If I turn the boost down 1 psi on my current tune will I get any negative affects? I'm tuned @ 23.8psi on pump 91 with a TBE, ETS 3.5'' FMIC, ETS intake, ETS uicp & licp, walbro fp, and mbc. Can I drop it down to 22psi without a retune?
Sorry for the silly question but I'd rather get flamed for asking instead of blindly doing things
Thanks
Thanks
no offense but I rather listen to a professional tuner...then again if i were to turn down the boost then I'd do more than 1
you dont need max boos to get your car to move. most of your driving is actually spent in low boost. so turning down one psi will not cause any ill effects.
then again i think turning down one psi is going to do much of anything.
Thanks guys. My shop/tuner is pretty far away from me, about 120 miles one way. I'm going back early feb. to change a few things around so untill then I just wanted to lower it 1 psi. My tune is rock solid with no knock but it's a comfort issues with me, I'd feel better with 22 psi lol
sssr20det510
13
Dec 9, 2014 10:39 AM
Judojack5
Jan 10, 2013 05:32 PM
Boostfarmer
Nov 2, 2012 01:22 PM
evolution253
May 16, 2009 12:27 PM
i like the way you worded that! for the OP, the only thing bad that will really happen if you turn the boost down is you will lose a little power!
