Which blow-off valve is good for the evo 8
So the only solution for stalling is an EMS? I've installed the Greddy Type-S BOV and I had problems from day 1...and it was recirculating... Then I pulled out one spring and it whistled like a ****in' bird..
yes to solve the stalling issue u need some way to lean out the low RPM's when the BOV falls to idle. The air tha tthe ECU has calibrated for is now gone and the fuel is still there, so you need to lean that portion out.
AFC can, there is a setting for low idle or sometihng i'm not exactly sure what it's called if no one can answer it quickly i'll go fiddle though my AFC and find it.
We have supplied many of the Forge Bovs worldwide with no problems , we supply both the Bovs and the recirc / diverter valves to Ralliart in several countries , all Forge valves are serviceable and guaranteed for life .
The Forge Bov and recir valves are direct OEM replacements that need no modifications or fitting kits
I have the Turbo XS-RFL and i have no problem what so ever...If your car begins to have some surge problems...In the kit, they supply these spacers that look like giant washers, which are used to tighten the spring inside the BOV...over all, installation is very easy, also tightening the spring is also easy...
-John
-John
I had the recirculating Forge valve in my EVO. I sold it. No matter what I did it would flutter,bad!! I tried all the springs-flutter-different positions-nothing but flutter!!! Maybe it works for some guys, not for me or a fellow EVO owner. This valve flutters at any slight lift off. The stock valve works 100 times better than the forge, the only bad thing is that it will not hold boost at high levels. My 2 cents.
Originally posted by 1QWKEVO
i don't understnad how one can say a VTA vs. recirc is better or visa versa... It's all about tuning, the valves job is to stay closed while the vehicle is under load (on the gas) and open to release pressurized air then close when the throttle blade is closed... SAME JOB... Only advantage that a VTA has over a recirc is that you may gain a few horses from reducing the turbulance(excess dumped air) from the inlet pipe as well as being able to completely remove the dump tube, I believe aftermarket inlet pipes do not contain dump tubes but only contain the fitting. Plus VTA BOV's make the really cool noise that makes people jump
However if you are planning on running propane injection DO NOT use a VTA BOV!!! I wouldn't even use a VTA BOV if I was running alky injection, I don't want that stuff all over my motor.
Hopefully that helped a bit.
However if you are planning on running propane injection DO NOT use a VTA BOV!!! I wouldn't even use a VTA BOV if I was running alky injection, I don't want that stuff all over my motor.Hopefully that helped a bit.
Incidentally, I use a 1G, which cost less than half of something like a Forge, does not flutter, and has been tested to hold way more boost than I will ever run.
timskyline86
24
Apr 9, 2009 07:27 PM
atmosferic, atmosphere, blow, bov, evo, evo8, evolution, good, making, recetclating, recirc, recirculated, reviews, run, stall, valve
