Spark plug cover cracked!
Old Dec 6, 2009 | 12:01 PM
GgreyEVOIX's Avatar
Exclamation Spark plug cover cracked!
This morning I got up to swap out my K&N cone filter before I hit the canyon roads and noticed that my spark plug cover was cracked. The crack is on the bottom right side around that bolt and now the right side is slightly bent upwards. Is this bad? Should I be worried about it? Will it cause me any problems? I'm going to order a new one on monday, probably carbon fiber, will I be fine with a cracked one till I replace it?
Old Dec 6, 2009 | 12:03 PM
Bobster22388's Avatar
If it is your sparkplug cover and not your valve cover, I wouldn't be too worried about it. If water fills up down there then you have to worry about it getting on the coils, but all it is there for is to keep stuff out. It should not affect anything else. You could also get a washer and put it around the bolt so it holds down more of the surface of it
Old Dec 6, 2009 | 12:05 PM
X_Evo's Avatar
Mine had been cracked in the same exact spot. Hadn't run into any issues with it being cracked either. Rode around like that for quite some time.
Old Dec 6, 2009 | 12:12 PM
20gmr's Avatar
I think they all crack. everyone I have seen that is not new or almost new is cracked. it seams like the plastic shrinks as the bolt holes line up sh*ty once you remove the cover.
Old Dec 7, 2009 | 12:30 PM
GgreyEVOIX's Avatar
It's raining right now, how worried should I be?
Old Dec 7, 2009 | 12:36 PM
gsrboi80's Avatar
You shouldn't be worried at all
Old Dec 7, 2009 | 05:12 PM
barneyb's Avatar
The cover doesn't seal. Plus, there is a drain hole (if it isn't plugged with dirt). The cover is there for looks.
Gamble
Jun 11, 2015 08:31 PM
randomdriver
Nov 10, 2013 09:06 AM
Spac3clown
Oct 16, 2010 11:18 PM
evo8nyc
Mar 20, 2008 06:44 AM
antiworldinc
Mar 16, 2006 03:16 PM
