Shiv comment on C&D
Old Oct 27, 2003 | 10:11 AM
  #46
Noize's Avatar
EvoM Administrator
I'll offer posse backup to whoever says test pipes smell horrible. They do!
Old Oct 27, 2003 | 10:20 AM
  #47
Eric Lyublinsky's Avatar
Originally posted by ShapeGSX
I only have one child, actually, and I plan to keep it that way. He gives us enough trouble.
One problem with having a cat is that you can't run leaded race fuel with one. And these cars definitely love race gas.
Ya well i'm not a fan a leaded race gas because what it does to the 02 sensors. I rather use pump gas or 104 oct. If I had a nice Hemi Cuda then Leaded it is..
Eric
Old Oct 27, 2003 | 10:30 AM
  #48
ShapeGSX's Avatar
I go through an O2 sensor maybe once every 2 years. Mitsu O2 sensors are very lead tolerant. The ones you have to worry about are the ones that have small slits leading to the element. Those get clogged easily and will die quickly.
Mitsu O2 sensors last quite a while with lead flowing over them.
Old Oct 27, 2003 | 10:58 AM
  #49
shiv@vishnu's Avatar
The tiny problem with running test pipes is you turn your car into an ozone-munching, smog-producing, gross polluter.
shiv
