Max Boost on Stock Turbo
Old Dec 23, 2009 | 02:16 PM
4DR's Avatar
4DR
Here is something to keep in mind. When people say "I run 27psi all day on pump", what they are trying to tell you is that the boost is set to allow the spike (the initial ramp up of the boost) to hit the 27psi mark....it doesn't stay there and you must know this. I run the same 26-27psi on pump daily, but by 7k I'm down to 21-22. When i run 30psi on 100octane I see 24-26psi at 6800-7000 rpm (its very cold in NY). stock 9 turbo btw. My 8 turbo went after very few 30psi spikes
4DR's Avatar
4DR
Originally Posted by PlanoEvo
On 93 i was able to get 28 spike on pump without much knock. i have tbe plus 4in ets core with a cop.
nice. any drivabilty difference with the cop?
Old Dec 23, 2009 | 02:20 PM
GgreyEVOIX's Avatar
OP are you still on the stock injectors and fuel pump?
Mellon Racing's Avatar
Originally Posted by ryno529
I have seen the evo9 turbos in the rally cars spike 38psi and hold 32-34 but they only hold up for a few races. I have seen the 9 turbos at 28-29psi on pump gas for an on the edge street tune. As for the 8 turbo the most i have seen is 29-30 psi and for a pump gas tune 25-26 psi .
are you sure that's a stock 9 turbo hitting 38psi and holding 32-34psi?
Old Dec 28, 2017 | 12:04 PM
honki24's Avatar
On my X (fully built 2.4L high compression motor) I'm experimenting with maxing out the stock turbo to get the most torque out of it possible. I can get it to just barely touch 35psi but it tapers badly to 15psi by 7K. This is on E85, don't try at home. I find the same as BLKCarbonEVO. I get 450ft-lb of torque with maxed out boost but HP tapers out to the same 400whp whether I peak at 30psi or 35psi.
Old Jul 26, 2018 | 10:11 AM
TariqEvo's Avatar
I guess we will never know 🧐
David Buschur
Sep 17, 2020 06:33 PM
Cirielmd
Dec 13, 2017 06:41 AM
GSX_TO_EVO
For Sale - Cars For Sale
Jun 9, 2016 08:35 AM
llDemonll
34
Mar 23, 2016 03:08 PM
