A little help..
Old Dec 14, 2009 | 04:22 PM
evo8nfs's Avatar
A little help..
Ok so today I was doin some routine maintenance on the evo. An oil change and such.. I did a compression check which numbers came out normal. I also did a boost leak check and found that the #4 valve cover spark plug ring gasket is leaking.. For the past few days I have noticed that my idle has been jumping all over the place holding 2k while sitting.. I have already checked my tps and iac sensors they are good to go.. The seals are getting replaced regarless but would like to figure this idle issue out! thanks guys any help or thought would be great!
Mod list:
3"TBE
Ported coated o2 housing
Ported stock Exhuast manifold
B/C 280 cams/ valve springs retainers
HKS cam gears
Injen I/C kit
Magnus Intake Manifold
Walbro 255
Old Dec 14, 2009 | 06:33 PM
evo8nfs's Avatar
Bump for some help!
Old Dec 15, 2009 | 03:11 PM
Bobster22388's Avatar
Did you check to see if your PCV valve is not stuck?
Old Dec 15, 2009 | 07:41 PM
evo8nfs's Avatar
PCV Valve is nice and clean Thanks for the idea though!
Old Dec 15, 2009 | 08:13 PM
Kracka's Avatar
Fix your boost leaks. I'm thinking your PCV valve is leaking otherwise you have blow-by since your crankcase is pressurizing. You might considering picking up one of these sets: http://www.maperformance.com/map-cra...acuum-kit.html
Old Dec 15, 2009 | 08:14 PM
Did you also check to make sure you didn't bump any vacuum lines by any chance?
Old Dec 15, 2009 | 08:20 PM
evo8nfs's Avatar
yea. all vaccuum lines are good its just that one seal is leaking... once i replace it I will see how the idle is.. This one has got me stumped ;(
fostytou
359
Oct 23, 2025 09:54 AM
TheBigD
Oct 5, 2012 08:07 PM
BlackonBlack2
May 14, 2012 07:25 AM
EvoIXMR
Nov 19, 2008 04:10 PM
BluEVOIX
Apr 3, 2007 11:52 PM
