4G64/MIVEC/FPBlack 1st Impressions
Old Dec 19, 2009 | 11:36 AM
JohnnyTSi's Avatar
Of note is that this car is completely untuned yet, I flashed my old 92 octane stock 2.0 IX tune into the ECU so I can't yet thrash on the car as it is running way lean resulting in some knock. I can also tell that the MIVEC tables need some major tweeking over the 2.0 map.
The first thing I noticed is the extra off boost torque when driving in traffic, very nice!
The 2nd thing I noticed is that the FPBlack is very chatty, the damn thing sounds like a Kenworth truck when driving in the 2500-3500rpm range, throttle modulation in this area results in whistling a turbo tune that is very noticeable from the drivers seat.
Did I mention the off boost torque? YES!! it really is a big improvement over the 2.0, I think that Mitsu should have put this block in the EVO instead of the 2.0.
I'm running on wastegate pressure (19ish) It looks like initial spool is in the 3800 range (remember the car is still untuned) and I still have the 3" intake and stock MAF. I'm confident that Aaron can get that down into the 34-3500 range that I was expecting with a 2.4.
I've still got a few things I need to clean up, When the 2.0 block blew up, a piece of block ended up in the radiator, it punched a small hole in the core. I managed to repair it to get the car running, but I don't trust it! I have already picked up a replacement and will swap it in today.
OK, that being said, I can't wait to schedule some time with Aaron and Lucas at English Racing to get the tune dialed in so I can turn the boost up.
  • 2.4 block modded for MIVEC oil feed
  • JE 9:1 pistons
  • Eagle rods
  • Power Enterprise Head Gasket
  • L19 Head Studs
  • GSC S2
  • fp springs
  • AEM Exh. cam gear
  • Modded MIVEC cam gear
  • Magnus cast intake manifold
  • PTE 1200cc Injectors
  • ETS 4" Intercooler with short-route pipes
  • Forge BOV
  • ETS intake pipe
  • Hallman Pro MBC
  • FPBlack ported
  • stock port matched exhaust manifold
  • Megan O2 Housing
  • Perrin 3" DP
  • 3" Test Pipe
  • HKS HiPower cat-back
Planned for the near future
  • 4" Intake pipe and huge filter
  • SD conversion (Already have all the parts)
  • dual pump conversion (I already own a Full Blown)
  • FIC 1650 injectors (I already own a set from my DSM)
  • e85
MIVEC Block Oil Feed
MIVEC Head Oil Feed
Next Up:
Old Dec 19, 2009 | 11:59 AM
JohnBradley's Avatar
Nice Johnny...
Cant wait to get it on the dyno. Grab the global (scaling) and drop it down to richen it up some just to be safe.
Old Dec 19, 2009 | 01:04 PM
FathouseFab's Avatar
Nice looking setup man.
Fathouse
Old Dec 19, 2009 | 01:12 PM
JohnnyTSi's Avatar
Fathouse
Thanks, not nearly as nice as some of the fab work I've seen you post up.
This setup should be acceptable for my commuter car!
John-
Old Dec 19, 2009 | 01:56 PM
JohnnyTSi's Avatar
I've had a couple of PM's asking about my setup, I'm running:
L19 Head Studs
The modded MIVEC cam gear details can be found here starting on post# 115: https://www.evolutionm.net/forums/ev...d-build-8.html
John-
Old Dec 19, 2009 | 03:21 PM
Power enterprise HG number- 1001-GM223
Old Dec 19, 2009 | 03:37 PM
JordanS4's Avatar
Awesome build. For DD I love my MIVEC 2.3 with the FP White. This thing is probably just as fun around town but a pure monster on boost...
Old Dec 19, 2009 | 03:42 PM
jezzy101's Avatar
Veteran: Marine Corp
Thanks for the info!!
JohnnyTsi,
Thanks and best of luck with your setup
2.4/FP Black = TQ Monster
Old Dec 21, 2009 | 07:17 PM
Someone went to the dyno today for his break in tune
Here is a log-
I think we can push the 92 tune more still pretty easily, the 1s were VERY intermittent. Boost is a little low for what I think it can do, and I think the S2s might respond to some tuning on the 2.4 that they dont normally seem to like on the 2.0l. I am going to let Johnny post his power numbers though.
Keep in mind on a stock turbo with all of his other parts on the stock 2.0 he was 383/355 on a 29psi spike on pumpgas. His car really really really likes boost. The MIVEC was being inconsistent a little (not sure why) and would really help us out and get the boost down to 3800 or so (27psi) or seem to do what it did in this log and linger at high rpm.
Also- break in= conservative...this is on the factory knock control settings so the noise might not even be real.
Old Dec 21, 2009 | 09:38 PM
dambikeracer's Avatar
I really like it!!! That's what I want! What are your HP goals?
Old Dec 22, 2009 | 03:34 PM
Something like this
https://www.evolutionm.net/forums/ev...2-chevron.html
Old Dec 22, 2009 | 04:13 PM
miragevo's Avatar
Veteran: Navy
What is the part # for the relays used with the Full blown dual pump system? They look real nice. Awesome set-up!!!!!
Old Dec 22, 2009 | 07:10 PM
JohnnyTSi's Avatar
The relays did not come with the full blown kit.
I've had two of the cheaper 30 amp relays burn up on me so I started using these:
They are 12V 75 Amp
Bosch Part# 0-332-002-150
Bosch sold their relay division to Tyco which has a different part# V23232-D0001-X001
It is the same relay though, just has a different brand name stamped in the side.
John-
Old Dec 22, 2009 | 07:14 PM
JohnnyTSi's Avatar
I was looking for "somewhere" around 500 on pump gas, and 600-650 on e85 would be icing on the cake.
John-
Old Jan 18, 2010 | 06:25 AM
MJ23FE's Avatar
Great build! I'd love to build a 2.4 with MIVEC when my motor goes poop.
Can't wait to see the finished numbers when your issue gets sorted out and you're able to throw some more boost at it on pump and e85.
-Jalal
