2.1L Motor Build, I need your help!
Old Dec 20, 2009 | 01:37 PM
dambikeracer's Avatar
I'm looking to build a 650+ WHP 2.1L motor. I found that I am going to need a 4G64 block and longer rods. What else am I going to need to install this in to IX?
Looking to also run high compression, thinking 11:1. Who makes 11:1 for the 2.1L? Anything else I need to know about 2.1L pistons?
What crank am I going to need? 4G63 or???
What lenght of rods?
Planning on running my FP Red or a new Black Turbo to get me to that 650+ WHP!!! Will only run E-85 or E-100.
Old Dec 20, 2009 | 01:58 PM
Is it best just to get a complete kit like this?
https://secure.buschurracing.com/cat...dfda9e05878883
Or even, having it assembled like this?
Old Dec 20, 2009 | 02:29 PM
Joshs EVO's Avatar
Have it assembled and sent to you. I wish I had me engine built by someone else. Never know with the shops past but with DB it's reliable. Move the GRP rods too. Make that puppy spin fast. See if he can knife edge the crank too.
Old Dec 20, 2009 | 02:45 PM
For some reason, I knew that YOU would say, have it assembled and sent to me But I know that Tobz would really like to build my motor!
On another note, you ever get that thing running with the dual fuel rail setup?
Old Dec 20, 2009 | 03:01 PM
20gmr's Avatar
if its going in a ix you will need to modify the mivec cam gear and also come up with a solution for the mivec oil feed from the block. Without looking into I am unsure what pin height pistons and what length rod you need to use. I encourage you to read over the article in engine turbo and drivetrain called "to stroke or not to stroke"
Old Dec 20, 2009 | 05:01 PM
CO_VR4's Avatar
Magnus Motorsports has more proven stroker combinations than anyone else I know. They make a long stroke 2.1 and a 2.2. Get more information here: http://www.magnusmotorsports.com/engines/dsm.htm
They also sell pistons with compression ratios that are not shown on the page...
For a 2.1, a standard 4g63 crank
Depends on whether you are building a destroker or a long rod version. Standard rod with a bore increase and appropriate pistons, or a long rod (better rod ratio) with a bore increase and appropriate pistons...
Old Dec 20, 2009 | 05:02 PM
Joshs EVO's Avatar
My car nope. The car runs, it works I just took my fuel injectors off and my BOV and sold them to some other people. So the car would run. but I am tapped out for cash for the time being and besides I don't drive it in the winter anyways.
It may not be running for a while till next yr cause if it all works I won't be here in May-Sept of this coming yr so there is no reason to fix my car when my future is a bit blurry right now.
Old Dec 20, 2009 | 05:13 PM
JohnBradley's Avatar
The 162mm / 88 mm combo ends up at 1.84 and the 156/88 combo is 1.772.
Compression height on the 2.1 pistons is around 1.13", the 156mm are going to be 6mm more, so 1.366 almost stock I think.
Old Dec 20, 2009 | 08:49 PM
project_skyline's Avatar
I would just let buschur assemble your whole long block. That way you don't have to worry about anything and everything is done right the first time. Besides buschur will stand behind his work in the event of a failure about 99.99% of the time.
I agree with josh on doing alum rods as well.
Old Dec 20, 2009 | 09:18 PM
evovin's Avatar
Get this! 8sec proven. PM me ( Its not as expensive as other competitors)
TurboTrix Racing 2.1 Motor w GRP Rods
iPhone pics only
They also accept core exchange
Its the same 2.1 motor that Brandon using when he ran 8sec
http://www.youtube.com/watch?v=F2gVZNU3lLo
http://www.youtube.com/watch?v=qh***6qNpgA
Old Dec 21, 2009 | 08:49 AM
[QUOTE=evovin;7818324]Get this! 8sec proven. PM me ( Its not as expensive as other competitors)
What's the cost? And what kind of crank and pistons are those?
Old Dec 21, 2009 | 10:32 AM
evovin's Avatar
pm sent
dambikeracer
25
Sep 14, 2015 10:44 AM
Frew
24
Dec 15, 2013 11:46 PM
babaz7
22
Mar 26, 2013 11:53 PM
dambikeracer
57
Mar 14, 2010 07:43 PM
dambikeracer
99
Feb 15, 2010 09:14 AM
