having car issues: need help
Old Dec 22, 2009 | 04:48 PM
Force-Fed Performance's Avatar
,<<<<<<gives up,
Old Dec 22, 2009 | 04:50 PM
ch53avitech's Avatar
Originally Posted by 05blue8
Both are common issues, just going to cost you a bit of money, o2 sensor and IAC, you'll be fine as long as you can stand the idle fluctuation, it annoys the **** out of me personally
I can get an OEM o2 sensor at Advanced for about $80, I might do that. How much can I get an IAC for?
Old Dec 22, 2009 | 04:56 PM
Originally Posted by Force-Fed Performance
,<<<<<<gives up,
Don't give up. I was typing when you submitted your post.
Old Dec 22, 2009 | 05:03 PM
So Justin say's it's the IAC. Where is that located and how simple is it to replace? I might order one and have it meet me in Tennessee.
Old Dec 22, 2009 | 06:05 PM
sktng22's Avatar
my car did the same stuff when one of the o2 sensors went bad
Old Dec 22, 2009 | 06:13 PM
Did your front or rear sensor go bad?
Old Dec 22, 2009 | 07:31 PM
How hard is it to swap IAC's? It's just the black circular thing with a plug on it right?
Old Dec 22, 2009 | 07:50 PM
crewdawg130's Avatar
its easy but expencive. is about 250 new. take it off its only 3 screws. Inspected and call me.
Your rear O2 dont control crap. you can take it off and youll only get a CEL.
Old Dec 22, 2009 | 08:15 PM
Originally Posted by crewdawg130
its easy but expencive. Is about 250 new. Take it off its only 3 screws. Inspected and call me.
Your rear o2 dont control crap. You can take it off and youll only get a cel.
nvm
Old Dec 26, 2009 | 05:21 AM
alicea8541's Avatar
Originally Posted by ch53avitech
First off. I recently figured out my car popped a p0138 (o2 sensor high voltage). I ran with it still on for about a week. Today I noticed my car was idling awkward. The RPM's would fluctuate between 1.5k-~2.2k rpm and the ARF was in the 10-11. Cruising at 55mph the afr are around 17-18 if I remember correctly. So I was thinking the rear o2 sensor is done for. Can someone tell me what's going on?
I don't see it on your original post.
I have a TBE w/ test pipe and a UEGO fyi. I'm driving home about 430 miles tomorrow. Will I be fine until I get it fixed when I get home?
Still don't see it.
BTW that car ran perfectly fine until today. And I've been running with the P0138 for about a week.
Nope, not here either.
I thought p0138 is the rear sensor. "o2 Sensor Bank 1 Sensor 2 Hight Voltage"
Common trend here.
Just an update for you guys. I just went to Advanced Auto and I also have P0507: Idle Control Sys. RPM high. Is this being caused by the fluctuating idle due to the o2 sensor?
Oh, there it is. I never saw this post.
Old Dec 26, 2009 | 09:28 AM
nvm
nvm???
did you fix it?
Slim Chance
Lancer Troubleshooting
Jul 7, 2013 02:16 PM
painstylez
Nov 17, 2012 12:41 PM
EvoJoeIX
Dec 8, 2010 10:32 AM
broddey
Feb 18, 2008 02:06 PM
fastassfourdoor
Jan 30, 2007 06:42 PM
