BBK full injector sizing choices choices!
Old Jan 2, 2010 | 04:10 PM
Davethewave's Avatar
well, none of those e85 stations are anywhere close to where i live. and puyallup, auburn is like 12 miles away. what would i do if i ever ran out of gas and that was the only station with 101oct? i would be screwed.
ok ive decided on 880cc precisions. im partial to precision because this is what i had on my old evo
Old Jan 2, 2010 | 04:28 PM
evo unknown's Avatar
the bigger the better..1000cc..if u wanna do e-85 1000s would be good, but bigger may be better.
Old Jan 2, 2010 | 05:03 PM
BluEVOIX's Avatar
My tuner recommends going with FIC 1450's. You'll run lower duty cycle, create less injector heat and have as much fuel as you would need.
Old Jan 2, 2010 | 06:10 PM
awd2gen's Avatar
1450cc are to big for that his setup. Even with e85 1200cc injectors would work well. after 1250cc injectors idle can start to get a little rough and is unnecessay to deal with in the OP setup.
Old Jan 2, 2010 | 07:32 PM
well everyone seems to keep forgetting that the OP (me) cant use e85 because there isnt even 1 single station close to me. and then if i ever decide to go on a road trip ill have to get reflashed. screw that noise. 92oct pumps are everywhere up here.
that is al i will use, pump 92oct. 880cc injectors should be sufficient. i dont have dreams of going for huge power with crazy mods. i did that with my last evo and it trew a rod. i just want a bad @ss power band, crisp shifting and suspension. the only turbo that can offer me what i want is the BBK full
Old Jan 3, 2010 | 07:46 AM
CBRD's Avatar
I would use atleast 780s.... We run 780s to 1200s depennding on the car!!!
Old Jan 3, 2010 | 12:37 PM
norcalSRTrida's Avatar
id recommend injector dynamics 1000cc high imp injectors. high quality injector, w/ some headroom.
Old Jan 3, 2010 | 12:41 PM
tiffsevo's Avatar
i am running 880's
Old Jan 3, 2010 | 03:38 PM
TK40's Avatar
Will 1000cc work for an e85 setup, or are 1200cc recommended?
I want to run a dual tune, one for 93, and one for e85. Trying to figure out what the ideal size injector would be.
Old Jan 3, 2010 | 04:20 PM
bbyevo8u's Avatar
^^ where are you getting e85 from in ny? what engine management system do you have?
Old Jan 3, 2010 | 04:40 PM
awd2gen's Avatar
Need more info on your mods to know what size you need.
Old Jan 3, 2010 | 05:19 PM
TK40's Avatar
E85 is all over long island, not that difficult to get. I want the dual tune though bc I only plan on playing with E85 in the summer.
I will be doing gsc s2, arp studs, and a fp red/black, haven't decided my injector choice yet. It all depends on what will work best with the dual tune.
Rest of my bolt ons are:
ETS 3.5"
Upper + Lower pipes
Intake
Walbro 255
Halman Pro RX
Megan o2 housing Ported
Greddy Ti-C Full
OEM engine management
Old Jan 3, 2010 | 05:20 PM
TK40's Avatar
Will probably do a ported exhaust manifold before I do the turbo as well.
maperformance
178
Jun 16, 2017 08:40 AM
maperformance
EvoX 'For Sale' External Engine / Power
109
Feb 9, 2016 09:09 AM
maperformance
391
Apr 23, 2014 11:10 AM
maperformance
404
Apr 23, 2014 11:07 AM
ChrisCarey
Jan 18, 2010 08:53 AM
