New ETS intake?
Old May 26, 2010 | 10:56 PM
  #31
jrhonda's Avatar
Originally Posted by Aven
Yeah that's what I had to do jr, but man was it a tight squeeze, I even attempted dropping the coupler in hot water to loosen it up. Well eventually it did go on.
I will be doing your modification this week.
Good, you will be satisfied. Just try and cut as straight as you can with a sharp razor blade. Draw a line first as well.
Old Aug 13, 2010 | 12:55 AM
  #32
akeric's Avatar
I just had the pleasure of installing this intake this evening. It turned what should have been maybe an hour max into a 2 1/2 hour job. The coupling that goes on the maf housing is a PITA. I used some carb clean to lube it up and it went on eventually. Almost lost a fingernail like a earlier poster.
I was able to get it to fit without cutting and without the filter rubbing much. If it is rubbing its so minor I don't care. It seems that it touches the fuse box if anything, I bent the ACD bracket just a bit to keep it out of the way.
I'm running the AMSOIL dry fly FYI.
Old Aug 13, 2010 | 01:21 AM
  #33
evilempire76's Avatar
Yeah, I can't believe how tight the coupler is that supposed to go to the MAF. Its rediculous! I got mine on, but I took a good bit of fiddling with things to get it on there the way I wanted it to go. I also fabbed up a bracket to keep it off of the ACD reservoir. What did the Amsoil filter cost? Do you know the part number?
Old Aug 13, 2010 | 07:22 AM
  #34
4doorstreetbike's Avatar
got the old style type with a 9 inch k&n fliter to fit without touching anything nor did I cut anything either..
Old Aug 13, 2010 | 12:31 PM
  #35
akeric's Avatar
It was the EAAU4560 and it costs about $50 shipped.
ETS Michael
EvoX 'For Sale' External Engine / Power
12
Dec 24, 2015 09:30 AM
ETS Michael
ExtremeTurboSystems.com – WA
Dec 24, 2015 09:29 AM
XTR Performance
95
Nov 10, 2014 02:09 PM
ETS Michael
109
Jan 29, 2013 11:03 PM
ETS Michael
65
Jan 8, 2013 02:45 PM
