Who replace their washer on every oil/fluid change?
Old Oct 27, 2003 | 03:20 PM
JT-KGY's Avatar
Did my fluid changes (oil/transaxle/transfer/rear diff) over the
weekend... it was not until late Friday that I realize I didn't have
the replacement crushable washer for my oil drain plug.... I
headed down to nearest dealer... turns out that the
washer cost a whopping $1.30+????? Just out of curiosity... I
headed down to the Honda dealer right next door... washers
are a mere 28 cents each... Even my $5 BMW OEM filter come
free with washers (as a kit)...
Why are washer cost so much more...
I'm not really ranting here.. as adding another $1 to my oil change
will not kill me... but just really curious why does it cost so much??
Also the washer that I remove from factory is silver colored and
flat... instead of copper colored and ring-like from the dealer...
Old Oct 27, 2003 | 03:24 PM
sr20det91's Avatar
I would'nt worry about it.
I have been changing them on the EVO, but I used the same one for 2 years on my WRX without a leak.
Old Oct 27, 2003 | 06:21 PM
propellerhead's Avatar
Well. the dealer that I bought my filters from gave me a buy 2 get one free deal and threw in a washer for each filter I purchased.
FWIW, the washers used on the Evo drain plug are the crush type, at least the ones supplied to me. Not just soft aluminum or brass flat washers but a sandwich design that cruches once. I'm sure you could reuse them but why bother?
Old Oct 28, 2003 | 09:50 AM
Technoz's Avatar
How do you get the washer out? Mine was smashed into the drain plug and I couldn't get it out.
Old Oct 28, 2003 | 09:58 AM
sr20det91's Avatar
I used a putty knife. Its was a pain in the *** though.
Old Oct 28, 2003 | 10:08 AM
webguy330i's Avatar
A flat-head screwdriver and some patience/finesse will remove it if it's stuck on.
I've always gotten the washer for free w/ the filter, it's always taped to the thing.
Old Oct 28, 2003 | 10:11 AM
jbrennen's Avatar
I wonder if you went to the same dealer as me, because I got the same buy 2 get 1 free deal. I had to ask for the crush washers, but they gave them to me for free. If I hadn't asked, they probably would have sent me merrily along without them.
Old Oct 28, 2003 | 12:30 PM
Fireball's Avatar
I wouldn't go to that dealer anymore if I were you.
Old Nov 4, 2003 | 03:42 AM
EvoPowerFreak's Avatar
It's much easier if you never change your washer... Just buy a fumotovalve. I have one on MY WRX, and one's on it's way for the EVO.
BTW I don't have anything to do with them I just think they are cool.
Old Nov 4, 2003 | 07:27 AM
evo 8 ya's Avatar
If you buy the OE oil filter from the washer comes with the filter
Old Nov 4, 2003 | 07:32 AM
Secret Chimp's Avatar
Just spray the drain plug with a good lubricant before putting on the next crush washer. It won't stick to the bolt next time you change your oil.
SC~
Old Nov 4, 2003 | 01:27 PM
For $25 you will never have to worry about that washer, or ever removing the drain plug again www.fumotovalve.com
That leaves more time for
Old Nov 4, 2003 | 02:33 PM
jbrennen's Avatar
Personally, I'd worry about failure of the valve, for instance if a large stone is thrown up from the road surface and impacts the valve. What I don't worry about is failure of a drain plug, especially when I personally install the crush washer and use a torque wrench to tighten it up.
To me, it doesn't make sense to take even the smallest risk with a $4000 engine, if the only benefit is saving two minutes each oil change.
Old Nov 4, 2003 | 05:43 PM
Not likely the valve is quite heavy duty. In fact the rock would probably do more damage to the oil pan than to the valve.
What I like more than the 2 minutes saved is the tool less oil change...
junk1337
Evo X How Tos / Installations
60
Jul 22, 2016 03:27 PM
ak47po
33
Mar 21, 2016 11:31 AM
D2003
Jan 4, 2016 05:35 PM
anjapower
Dec 21, 2005 06:51 AM
CuniTEVo8
Dec 19, 2004 09:03 PM
