Smell with race pipe
Old Oct 27, 2003 | 05:08 PM
Jev3gs's Avatar
I just installed my turboback exhaust with a race pipe and it stinks. Now I don't know if that is because the exhaust is brand new or what. Anyone here use a race pipe also, but the exhaust doesn't just smell horribly?
Old Oct 27, 2003 | 05:12 PM
Evo spooling's Avatar
If you are not using a catalytic converter, you will find that your exhaust stinks. If it bothers you terribly, look at a high flow cat. I assume that your race pipe omitted the cat.
Old Oct 27, 2003 | 05:14 PM
Jev3gs's Avatar
Correct, no cat. I know alot of people out there are running their cars without cats. If everyone's smells like mine I don't know how they do it
Old Oct 27, 2003 | 05:16 PM
kuniboy's Avatar
Yeah, mine stinks too. it gives me a headache. this is because the Evo runs extra rich. Every car with the cat removed will smell the same too.
Old Oct 27, 2003 | 05:20 PM
1QWKEVO's Avatar
thats becasue the evo rusn pig rich, ur smelling unburnt fuel, you will either get use to it, or buy a fuel controller and lean it out
Old Oct 27, 2003 | 05:25 PM
Ryanmcd2's Avatar
In Timeout
I am going to just go with a high flow cat. 5 hp is not worth that smell. Drive with the windows down and when you get out you will smell like gas.
Old Oct 27, 2003 | 05:26 PM
evolutionist's Avatar
I will play devils advocate here. I have the B&B downpipe and catback. There is a perin cat delete pipe or race pipe, whatever you want to call it, inbetween the two B&B pieces. I had the B&B exhaust pipe on there a least a month before the perin pipe. I have no noticible smell coming from the exhaust. Only when I put 100 octane 76 race gas does it give that sweet smell of power. Supreme 93 from 76 gives me no more smell than that of the system without the pipe.
Old Oct 27, 2003 | 05:28 PM
Jev3gs's Avatar
so is it safe to say that if I get a fuel controller I can lean out the fuel and most of the smell will go away?
shiv@vishnu's Avatar
It has little to do with running rich or unrich. You're smelling noxious combustion byproducts. Byproducts that are catalyzed by catalytic converters into H2O, CO2 and other benign stuff. Leaning things out with a fuel computer won't make the car less offensive.
My 2c
shiv
Old Oct 27, 2003 | 05:29 PM
Quickshift's Avatar
Get a S-AFC and that smell will disipate or high flow cat.IMO i would go for the s-afc for more powaaaaa!!!! or some other ecu
Old Oct 27, 2003 | 05:30 PM
Jev3gs's Avatar
Thanks Shiv. Now that is an answer I can believe. I guess I am going back to cat then. 5HP isn't worth it at all.
Old Oct 27, 2003 | 05:31 PM
lil'evil_evo's Avatar
It's for running so rich and because you have a new exhaust. When I got my HKS Hi-Power I had a horrible smell for a few days then it was gone, but I also still have my stock cat.
Ryanmcd2's Avatar
In Timeout
I know why, because yours has that 2 inch gap and all the exhaust leaks out before it gets out of the pipe lol. I am just kidding and being a smart ***. It should smell, they all do without a cat
Old Oct 27, 2003 | 05:32 PM
Jev3gs's Avatar
I always knew it would smell, but never knew it would be that bad though. I would of hated to drive behind me today
Old Oct 27, 2003 | 05:43 PM
As you've seen, running catless emmits a pretty distinctive stench which most cops will recognize. In CA, being pulled over and inspected will result in a *big* fine on the spot.
As for hp, we've seen as gains as high as 10-12 wheel hp with the cat removed (compared to a free flow cat). Pretty substantial gain. But not worth it, IMHO.
my 2c,
shiv
