I was in an accident the other day got out on some ice and i went sliding all over the road and off and it stalled out on me then when i went to start it up it cranked a long time and it turned over and it idle fine but when u load the engine up in gear it bucks and wont go above 1300rpm when its warm. no codes and when its is out of geart its mostly fine except it sputter at certian rpms. i only had the car a month and no clue realy whats done to it.
my hose popped off of my throttle body awhile back and i had the same kinda issue. Check all intercooler hoses.
i messed with it last night and got it to through a speed sensor code and its like the 3000 gt's if u get the bucking from them disconect the speed sensor and its fine. now i did put the BOV back on it poped off but i think thats because i had to pull the pipe off the throttle body and it pulled off with it on that setup on the injen intake. where gona try to get the PCM reflashed for the one recall. get back to u after its done.
