Ss Clutch Line
Old Jan 6, 2010 | 01:00 PM
Brsox10288's Avatar
I called them, they said its around $43.00 for the whole line. It came from a old post by silver surfer
Old Jan 7, 2010 | 04:13 AM
Kevin.'s Avatar
Originally Posted by Kracka
http://www.amsperformance.com/cart/M...rivetrain.html
AMS sells both the upper and lower lines.
I ****ing knew there had to be 2 lines. The ****ing techna-fit line is just the upper line. I wish I knew this before I bought that.
Old Jan 7, 2010 | 07:55 AM
dastallion951's Avatar
im runnin the ams upper line and ss lower clutch line and with my act hdss and prolite flywheel have a pretty consistent clutch pedal...recommended i would say so if ur tryin to get as much clutch travel as possible ditch the flexible line and restrictor pill haha
Old Jan 7, 2010 | 09:16 AM
Ted B's Avatar
I'm a firm believer in removing the pill on the EVO, and upgrading high pressure lines (e.g. clutch and brake) in any application. Anything that reduces line wall flex is a benefit. It's oftentimes the sum of small differences that add up to noticeable improvements.
Old Jan 7, 2010 | 09:31 AM
wizzo 8's Avatar
I took my slave cylinder off to remove the pill and couldn't see anything that was removable. I poked it with a small Allen wrench and nothing. I have had the car since new so I know it hasn't been removed already
Old Jan 7, 2010 | 10:20 AM
Skylineracer's Avatar
From: Clifton New Jersey Lived: Daytona Beach, Florida Lived: Port Orange, Florida
how important is the upper line cause isn't the upper part already a metal tube from Mitsu?
Old Jan 7, 2010 | 10:21 AM
fre's Avatar
fre
Originally Posted by MR Turco
i have the russell one. The install is terrible and honestly, i didn't notice a difference. I would recommend removing the clutch pill in lieu of the clutch line. That was a bigger, and better, difference in clutch response and feel.
If you do this, you might want to get the fork stop and/or (double wave spring) for your clutch/tranny. I have heard problems with the clips popping out due to the pill removal. My buddy had clip issues and he removed his pill. Now whether this was the pill only/mostly or a combination of that and buggering up an install I am not sure.
I am sure it's just one of those hit or miss issues that can be prevented altogether with the fork stop/double spring, but sometimes you can get by without any fix.
Old Jan 7, 2010 | 10:24 AM
Brsox10288's Avatar
I checked the link, is lancershops brand?
Old Jan 7, 2010 | 10:48 AM
MR Turco's Avatar
I now have a clutch with hydraulic TOB so it doesn't matter. But i drove about 10k miles, stock clutch with numerous launches without any issues with no pill. I have since removed the pill on a handful of locals cars all without any issues.
Old Feb 3, 2010 | 11:05 AM
Kevin.'s Avatar
The upper line is the rubber line. The lower line is a hard line. I don't really see the point now in replacing the lower line with a steel braided one. Only benefit I see in replacing the lower one with a braided line is if your taking your removing your tranny often.
Old Feb 11, 2010 | 10:18 PM
wshihdnevo's Avatar
I have known many people who have had the lower hard steel line crack and break on them and cost them a lot more than the $40 it costs for a ss line.
Old Feb 12, 2010 | 01:10 AM
Kevin.'s Avatar
I'll take my chances
Old Mar 6, 2012 | 01:08 PM
03BoostedVIII's Avatar
There are companies that offer a full line replacement in one single line. Not just 2 lines anymore. From my understanding they work just as well
Old Mar 7, 2012 | 05:19 AM
kingjamEvo's Avatar
Mine did crack and costed me a lot more than it would to replace it with a ss line.
tsitalon1
Apr 3, 2009 10:27 AM
beemerfreak
34
Feb 20, 2008 01:24 PM
exhaust_note
Aug 11, 2005 09:44 PM
4-BNGR
Jul 20, 2005 12:32 PM
Lowness
Sep 2, 2004 06:24 PM
