Ryu's hunting for 9's on the Stock Block
Old Mar 25, 2010 | 04:56 PM
  #256
RyuEvoIX's Avatar
Originally Posted by ssteve
sorry if its been posted but are you still on stock rod bolts or did you swap them for arp's?
100% stock bottom end. Neither the head nor the oil pan have ever been removed.
Old Mar 25, 2010 | 05:11 PM
  #257
SparkTech's Avatar
Good Luck...
sounds like you like the Black
Old Mar 25, 2010 | 05:54 PM
  #258
RyuEvoIX's Avatar
Originally Posted by SparkTech
Good Luck...
Thanks SparkTech. After I build the motor I may need one of your fantastic non cdi systems.
Thanks again to everyone else. I'm gonna do my best to not disappoint.
Old Mar 29, 2010 | 01:33 PM
  #259
Thugline's Avatar
u should try e-breaking ur launch this time...It will save ur drivetrain for sure.
Old Mar 29, 2010 | 01:39 PM
  #260
TTP Engineering's Avatar
What?
Old Mar 29, 2010 | 02:15 PM
  #261
RyuEvoIX's Avatar
I'm with TTP, "what?" My drivetrain is in perfect condition after hundreds of launches, but thanks for the advice.
Quick update: I have an appointment set for tuning at TTP on April 6th. As long as all goes well and the motor holds I am scheduling to hit the track April 18th.
Old Mar 29, 2010 | 03:45 PM
  #262
Silk's Avatar
Load up the drivline with the e-brake like a staging brake.
Not recomending you do it, that's just what he meant.
Old Mar 29, 2010 | 03:50 PM
  #263
That is meant for carbon clutches, not for cerametallic unsprung units.
Old Mar 29, 2010 | 04:12 PM
  #264
RyuEvoIX's Avatar
I understand what he was saying, just not why it was even being brought up. I preload the drivetrain when I stage up. You do not have to use the Ebrake to preload. I have never damaged my drivetrain from launching,
Old Mar 29, 2010 | 04:14 PM
  #265
Svendiesel's Avatar
Ryu, you said your heads never been off your block...you dont have aftermarket springs or retainers in your head?!
Or did you do the head-on-block spring/retainer job like the how to here on evom.
Old Mar 29, 2010 | 04:20 PM
  #266
RyuEvoIX's Avatar
Headstuds were installed 1x1 method along with the springs and retainers.
Old Mar 29, 2010 | 04:24 PM
  #267
EvoFlash's Avatar
How do you like TTP? I'm thinking about having my car tune there when I get my ported intake mani and TB back and then try for a 10 sec pass on pump only,stock block,
Old Mar 29, 2010 | 04:29 PM
  #268
RyuEvoIX's Avatar
TTP always gives excellent service.
Old Mar 29, 2010 | 05:55 PM
  #269
4G63Rules's Avatar
I am definitely making the trip to see this monster getting tuned!! I think Jerry wants to go too.
Old Mar 29, 2010 | 06:02 PM
  #270
RyuEvoIX's Avatar
Sounds good, just let me know.
