Question for Redline MT-90 fluid users
Old Oct 28, 2003 | 02:02 AM
JT-KGY's Avatar
Just put in 3 quarts of Redline MT-90 fluids in my car over the
weekend (10/25/2003)...
Finally drove the car for a while yesterday... I think the shifting
is notchier than when the car has factory tranny fluids...
Any other MT-90 user having the same problem... Stange thing
is that I think the shifting is smoother when engine is running
at higher rpms than low....
Maybe I'll just drive a bit more...
Old Oct 28, 2003 | 04:51 AM
okijack's Avatar
I have not noticed any negative effects from changing to Redline. The shift feel is about the same (Maybe slightly better). The biggest plus is the slight decrease in tranny decel buzz. That has got to be a good thing.
Old Oct 28, 2003 | 06:13 AM
Eric Lyublinsky's Avatar
Re: Question for Redline MT-90 fluid users
You might have over filled it. Some times when you have to much oil it could create a drag affect witch slows down the shifting action. I heard this once from a tranny builder.
Eric
Old Oct 28, 2003 | 06:28 AM
johnjonfenomeno's Avatar
Im about to change the oil in my car this weekend and I also want to change the tranny fluid and diff box fluid can anybody post some pics and tell me what fluids to use on the diff box. Please provide me instructions on how to do this... Thanks in advance
Old Oct 28, 2003 | 06:33 AM
Do a search there have bin a few good install posts.
MT90 Tranny
Eric
Old Oct 28, 2003 | 07:01 AM
webguy330i's Avatar
MT90 tranny, 75W90 center/rear diff.
FWIW I noticed improved shifting smoothness and overall feel after the change in my car, not to mention no more gear grinds (haven't had one yet in 3000 miles).
Old Oct 28, 2003 | 12:46 PM
JT-KGY's Avatar
I did it with the write up from runny_yolk
https://www.evolutionm.net/forums/sh...t=washer+fluid
and the shop manual..
Almost every bolt has torque spec of 23.... except the rear
differential where even the shop manual weren't clear what
torque spec I should be using for filler/drain bolt.
Old Oct 28, 2003 | 12:52 PM
JT-KGY's Avatar
Re: Re: Question for Redline MT-90 fluid users
I did try to fill it up as much as I can... after all I thought
overfill is better than not having enough fluid??
I fill up until it's spill out from filler plug a bit.... gave it few more
pumps (I pump in the fluid from under the car)... quickly remove
the hose... close the filler plug as soon as I can....
Anyways, I did use only roughly 2.9 quart of redline though... just
as what the manual says.
Eric
Old Oct 28, 2003 | 02:10 PM
mojo's Avatar
I just put MT-90 in yesterday and noticed an improvement in shifting. Less effort going into first, reverse also.
Old Oct 28, 2003 | 05:13 PM
USP45's Avatar
I noticed a little bit notchier feel when I first put it in as well, however after about 500 miles it has become much smoother. I have put a total of about 1300 miles on it since the change and it feels really good now. Actually, the shifting feel is very transparent now which is a good thing as before I used to notice how notchy the shifting was.
nor11384
Dec 30, 2016 08:18 AM
eddy5201314
12
Dec 24, 2016 04:33 AM
Evo3573
Nov 15, 2011 11:20 PM
Solo II Evo
Apr 22, 2009 03:08 PM
MitsuJDM
Aug 22, 2008 01:39 PM
