transmission fluids
Old Dec 27, 2016 | 04:40 PM
nor11384's Avatar
FCOTM Winner
transmission fluids
Ok guys i know this topic has been beaten to death but most of the threads are older so i want to know what people think now. I have been using redline mt90 in the transmission and redline heavyweight shockproof in the tcase. Ive seen threads where people say they mix the mt90 with something else because the mt90 when cold makes the tranny notchy. When the car is warmed up and start driving still feels sort of notchy. Other than that it shifts fine. Well, i adjusted the clutch according to jacks transmission video where he says to push in slave cylinder and adjust clutch but i feel that made it notchier than before. Do you guys think i should keep using mt90 or use some type of cocktail mix like others are saying here. Jacks transmission website and i think shepherd say to only use diaqueen or mt90 in tranny. I want to know your opinions. Specially those who used the mix and how much whp youre making.
Old Dec 27, 2016 | 08:34 PM
LetsGetThisDone's Avatar
You can try the amsoil 75w90 manual trans fluid. I found it to shift better than the redline.
Old Dec 27, 2016 | 09:20 PM
nor11384's Avatar
FCOTM Winner
something to think about...
Old Dec 27, 2016 | 10:23 PM
4b11slayer's Avatar
More then likely a mechanical/adjustment issue if its notchyer after adjusting. Could be broken welds on pedal assembly, bent release fork, etc
Old Dec 28, 2016 | 12:04 AM
Ferp's Avatar
I wanted to second this. I run Diaqueen OEM in my xcase. In my transmission I have tried a few different oils. Castrol, Redline, and Amsoil. The Amsoil has been the best so far. It and the Castrol oil shifted much better than Redline MT90 whilst the car is warming up and shift smooth as butter once the car is at operating temperature.
Old Dec 30, 2016 | 08:18 AM
benniboi08's Avatar
Yep I can attest to amsoil 75w90 for MTF. I have also used redline mt90, and OEM but for me Amsoil is also the best all around. I don't track the car but starting up in the colder months shifts a lot smoother than mt90.
I also use diaqueen Mitsu OEM fluid for the rear diff and x-case.
Eva01
13
Apr 14, 2005 03:34 PM
x7eVoLuTiOn7x
Oct 7, 2004 09:34 AM
chrisitr
May 2, 2003 09:23 PM
shawnhayes
Apr 13, 2003 02:45 PM
