How often to change out fluids in differential, transfer case and transmission?
That is exactly the question. Also what would be the best fluids to use? Is there any other piece I am missing a fluid change on (obviously aside from the engine?)
Eva01
Eva01
Originally Posted by titaniumkingpin
i believe the tranny fluid is every 15,000 and the diff - transfer case is every 25,000
i may be wrong though.
anyone else?
anyone else?
If you are stock, go by the manual that came with your car. Make sure your dealer uses the fluids reccomended in the Manual. Some don't and they'll fuuuuuuuuck up your car.
If you are not stock, as Team Rip reccomends, change them all when you change the oil.
In general, you can use any fluid which meets the factory specs (in the owner's manual). Pennzoil Syncromesh works, Redline works (I think) and Diaqueen (OEM fluid) works. I'm assuming you're on the stock transmission, if you're on one from TRE or someone else, do whatever they say.
I'm at 5K just changed (trans oil - Motul Gear 300 API GL-4), (Tranf. Case oil - Red Line 100% synth. GL-5). I'll post at 7K give you feed back. I started autocross coupled of months ago. They feel good and everything is running smooth.
Eva01
Apr 27, 2006 10:26 AM
2003, case, change, differential, evo, evolution, fluid, fluids, ix, lancer, mitsubishi, rear, transfer, transmission
