Woodpecker noise coming from trans/transfer case area Help!! please
getting a weird noise coming from my evo 8. does it between 2k to 4k rpms and when wot. checked the car for anything hitting and found nothing. its driving me crazy. also clutch goes blank sometimes don't know if that helps. thank you guys
If its not the boost solenoid activating.
Narrow down the area of noise.
Determine it is in engine side or transmission side.
Since your complaining of a clutch issue it could be the springs in the clutch disk have broken or fell out.
Regardless if it is coming from bellhousing area the transmission should be removed to inspect.
Disk
Pressure plate
Throw out bearing
Disk
Pressure plate
Throw out bearing
Disk
Pressure plate
Throw out bearing
Disk
Pressure plate
Throw out bearing
thank you very much for the reply. i appreciate it i will look into it. thanks again have a happy new years
yeap is in the driveline, its not associated with the motor. i double check around the motor just in case. thank you for the response i appreciate man
konstantinosIX
Jan 8, 2009 11:17 PM
oofastlineoo69
May 18, 2008 08:36 AM
