Transmission Help
Old Jan 12, 2010 | 04:38 PM
MitsoKid's Avatar
Transmission Help
Hey guys, some of you know I'm in the process of a 2.3L build.. I want to check out my transmission also, when I drained it earlier tonight the fluid was a little dark and very gritty. Very, very fine metal shavings throughout the fluid. This fluid is no more then 5,000 miles old. I change it every 10k..
How can I pull my tranny apart and take a look? I have never done transmission work before so I'm a bit hesitant to take anything apart
Old Jan 12, 2010 | 05:32 PM
thedru13's Avatar
I would recommend you don't. If you have never done tranny work I would not attempt it on your own. Not something that is easy in my opinion..
Old Jan 12, 2010 | 05:39 PM
MitsoKid's Avatar
so you wouldnt recommend me pulling the case cover off the side opposite of the bell housing area? I wasnt planning on taking anything apart, but just visually inspecting what I can see.
But I'm not trying to be difficult. If you dont recommend it then I wont do it.
Old Jan 12, 2010 | 05:40 PM
warstang27's Avatar
i wouldnt recommend doing it, if its very fine shavings its not a big deal and relatively normal wear and tear, once you start seeing decent sized scrapings thats when you should worry. just keep an eye on it, check it again in 5 thousand miles, and see if it has gotten worse or affected your shifting. btw what fluid are you using?
Old Jan 12, 2010 | 05:46 PM
evolution2186's Avatar
x2. I will add, if these shavings are after only 5,000 miles and very plentiful, keep an eye on it. A small amount of shavings will accumulate, most of which end up on your drain plug. I've ran Redline and had great luck with their fluid line. It sounds your a hands on guy. Props to you, and keep it up!
Old Jan 12, 2010 | 05:48 PM
Teal2nnr's Avatar
Do not open it yourslef.
Old Jan 12, 2010 | 06:03 PM
MitsoKid's Avatar
sounds good, i wont touch it.
I only use Redline MT-90.. and 75W-something, haha I honestly dont remember what weight it is...
75w-40?
I might upgrade to a dog box in the future. Its a track only car, so no worries about driving it too much
Evol Darwin
Nov 28, 2014 12:48 AM
apexbeast
May 11, 2014 12:38 AM
noscam
Jan 25, 2014 01:28 AM
shawnhayes
27
Jul 19, 2010 12:08 PM
RevMatcher
Jun 9, 2009 05:05 PM
