Wastegate actuator question???
Old Jan 14, 2010 | 01:30 AM
STWHY?'s Avatar
Going to be geting a red here shortly..And at the moment i dont have enough money for the 80mm comp housing,and upgraded wga..Which would you guys chose to order first??Is the 64mm housing fine with the upgraded wga??Or is the comp housing better on stock evo 9 wga??Any help appreciated..Justin
Old Jan 14, 2010 | 02:45 AM
1NastyMR's Avatar
Do it right the first time... wait till you can afford both the 80mm comp housing and wastegate upgrade... Its not much more for either so im assuming a week or two should be plenty of time to save up for it... Wont kill you to wait....
Old Jan 14, 2010 | 03:03 AM
EvoLutionized8's Avatar
Agree with 1NastyMR, just wait it out and get them both. Just to let you know the 80mm compressor housing does nothing for power, its for anti-surge. If you use your car for mostly drag, track time, then it shouldn't matter and just spend the money on the WGA. If you daily drive mostly, then recommend you definitely wait for both. good luck.. You won't be dissapointed.
CT9A PR
Jun 27, 2014 02:33 PM
vito93
Nov 24, 2013 08:20 PM
CDrinkH2O
47
Oct 17, 2012 08:13 PM
kevinlubitski
13
Dec 27, 2011 08:55 AM
stefano
Sep 7, 2008 07:25 PM
