New manifold or o2 housing?
As most people do I'm upgrading part by part and trying to decide between a new manifold or a o2 housing. I am keeping the stock turbo for now because I'm only looking to get 400+ whp. So far I have tbe, licp with short route (custom to keep the regular battery size) stage one cams,1120 cc injectors, walbro fuel pump, 25psi wga, and e85... If you have advice please give some... Thanks
I'd send the stock exhaust manifold off to buschur to be ported and coated that's the best bang for your buck and also jut have the stock o2 housing ported. In terms of gains there is not going to be much from an o2 housing.
I have an ar design hood dump o2 housing and it didn't feel like their was a gain of that much by any means. But in the long run porting the stocker will cost less then buying a new one from someone like map since especially it is a ported stocker.
Also a ported stocker has been shown on multiple Dyno pulls to make maybe a bit less then a tubular manifold however a rock ported is around 269 bucks vs 800+ for a tubular. Unless your looking to go with. T3 turbo setup in which case you'll need an aftermarket one.
WTB[Mid-Atlantic]: Evo X Manifold and Downpipe
Drew314
May 20, 2015 12:53 PM
IX_MR
Jan 16, 2013 07:44 PM
Aliengotpsi
May 3, 2010 09:58 PM
