NOTICE: turbo install kits- please read
Old Jan 14, 2010 | 07:45 AM
CBRD's Avatar
to anyone that has bought any "turbo install kits" recently to put an evo 9 turbo on an evo 8...
we've had a few here (because of the amount of BBK's we install) that we've purchased to utilize... and from time to time we have used different suppliers...
the last batch we have received have the wrong size hole drilled in both the oil feed banjo from the head and the banjo into the oil feed on the turbo itself...
the holes for the banjo feed are also offset and not properly aligned...
we do not normally use these fittings, as we just use the coolants hoses, gaskets, and such. Our general practice it to reuse all of the fittings from the stock turbo.
im working with the vendors we purchase these from to pinpoint the problem and make people aware, id hate to see a client with one of our turbos, FP, or other to lose a turbo because of these fittings!
cheers
here are pics... (sorry for the quality) i wanted to get them up in a hurry!!
cb
Old Jan 14, 2010 | 08:39 AM
gsrboi80's Avatar
All you need is the IX's J pipe to make any IX varient fit on an VIII. Either way good find CBRD
Old Jan 14, 2010 | 12:23 PM
Murf's Avatar
just to add a little to this. Inspect the J-pipe for pin holes around the flange weld..I have seen several that have had holes in them out of the box and right off the showroom floor.
CBRD
Mar 16, 2012 09:48 AM
CBRD
29
Dec 19, 2011 12:32 PM
CBRD
Jul 16, 2011 12:45 AM
CBRD
Feb 7, 2011 12:54 PM
CBRD
Feb 5, 2010 12:47 PM
