Underdrive pully cant be balanced :(
Old Jan 16, 2010 | 07:11 AM
maxims4g63's Avatar
So, my machine shop just called and said that they can NOT balance my rotating assembly with the Unorthodox Racing crank pulley. I thought since i opted for the lighter exedy flywheel they should not have a problem, but i guess not. anyone have any input on this,or know anyone who heard the same thing?
Old Jan 23, 2010 | 07:21 AM
MitsuJoe's Avatar
Get rid of the crank pulley and get a fluidampr.
I have seen solid crank pulley's scatter bearings in a few 2.3 applications.
Old Jan 25, 2010 | 08:13 AM
maxims4g63's Avatar
but...... what happens when its cold out and that fluid freezes?
Old Jan 25, 2010 | 08:20 AM
gsrboi80's Avatar
From their site
"It has been rumored that the fluid in a Fluidampr turns to gel over time. Here’s a news flash, its gel when we pump it into the damper. That is how the technology works. The silicone gel inside the damper keeps the flywheel in place and functioning. So to put all of the competitions claims to rest, it is a gel, always and forever. Maybe we should have named them Geldamprs" .
Also right from their site. Also its a silicone type gel 45,000 times thicker then 30 weight motor oil. No worries about using one of those
Old Jan 25, 2010 | 08:21 AM
MitsuJoe's Avatar
The silicone fluid is good at all temperatures. They run these things in military, aircraft and other applications that I am sure are more stressful than anything we can do.
Old Jan 25, 2010 | 08:27 AM
xRoguex's Avatar
Originally Posted by gsrboi80
From their site
Well that sure puts the theory to rest.
They do. I saw one on a 12 liter 2 stroke... that was about 14" across. Guess what was in it...
Old Jan 25, 2010 | 09:05 AM
E85evo8's Avatar
I'm running a fluidampr crank pulley on my built 2.0ltr and would recommend buying it to anyone!
Old Feb 19, 2010 | 09:58 AM
20gmr's Avatar
I just installed one for a guy locally. Nice unit, its pretty heavy which i kinda like because when you take all the rotating wait out the engine it gets tricky to pull out. the only thing I noticed is i thought it would fit tighter on the crank, when I say that I mean fit tighter to the dowel on the crank. The timing mark is on the pulley and pulley can be scewed either way a few degrees. not an issue if you are degreeing, which most of the motors this would be going on probably would be.
