Stock turbo 330 whp Dyno Flash
Old Oct 29, 2003 | 05:46 PM
DynoFlash's Avatar
This is a Pruven client who had previously been tuned on a SAFC II by another tri-state dsm shop red line is how he rolled in
Blue line is my custom Pruven version Dyno Flash - a bit leaner than the usual tune i do per Pruven specs b/c this guy has the Pruven fmic which allows us to go leaner
fmic
cams - 272
3" exhuast
HKS EVC V EBC
HKS intake
initercooler pipe kit
This is a 93 octane tune
Old Oct 29, 2003 | 06:14 PM
ez76's Avatar
I notice in many dyno graphs that A/F ratios typically descend from stoich. (or higher!) in the lower RPM's to a richer, flatter mixture curve in the back half of the range.
Why is that? What makes it safer to run closer to stoich. (or leaner?) at lower RPM's?
Old Oct 29, 2003 | 07:43 PM
mayhem's Avatar
are you going to post every customer's dyno graph?
Old Oct 29, 2003 | 07:57 PM
MYEVOVIII's Avatar
I think he is just trying to show the differences in power between a re-flash and SAFC II with the same mods
Old Oct 29, 2003 | 08:05 PM
Guru's Avatar
Because you are not making boost at lower RPM's so best to run 14.4 or so.
Old Oct 29, 2003 | 08:25 PM
DynoFlash's Avatar
Would you like me too? Or should I just post selected ones with various levels of modifications? I was thinking to post any ones which stand out for one reason or the other. I log more dyno time on evos than any one in the US and think its a good idea to share the data with this board. It helps me advertise and it helps the readers see whats going on with various modifications.
Old Oct 29, 2003 | 10:59 PM
GREDDY's Avatar
Just simply awesome AL! I hope to see you in CO. soon when I get a list going.
Old Oct 29, 2003 | 11:17 PM
Zeus's Avatar
Lay off, Al is posting what half the other tuners won't... Al needs a good kick in the ***, but not on this subject.
Old Oct 30, 2003 | 05:04 AM
94AWDcoupe's Avatar
Great scotts! Nice comparison.
what I am seeing is how poorly tuned the afc was when he rolled in. The afc tuned correctly will produce the same a/f line as any reflash can. Only difference is you can readjust it on your next mod. A reflashed ecu has to go back to the expensive dyno.
Old Oct 30, 2003 | 05:16 AM
jotan82's Avatar
nice numbers
Old Oct 30, 2003 | 06:45 AM
Zeus's Avatar
Mmmmm, no. No where near the resolution...
Old Oct 30, 2003 | 06:50 AM
SuperchargedGTZ's Avatar
but dont forget timing is also controlled by the re-flash
Old Oct 30, 2003 | 09:31 AM
DynoFlash's Avatar
A properly tuned safc will attenuate the MAF signal by up to 18 - 20 % on a car with these mods - whcih results in making the ecu think there is a significantly lighter load on the car and causes the ecu to run in a much higher ign timing table - - this results in serious knock activity and detonation which yeilds a bummpy, rough powerband
Being able to alter the fuel and leave the timing a load refernce at the same point is an invaluable tool
Also - we can adjust full boost part gas situations which piggy backs have a very hard time dealing with
