Rear Diff Options - Power Oversteer Found Here
Old Aug 17, 2010 | 09:49 PM
  #121
adnmoh1's Avatar
looks like i found the right thread, with respect to the op, everyone is going for after market diffs for the evos, what bout dropping in a j-spec or euro spec ayc rear diff and cross member?
pretty much have the car running the j spec evo 8 super ayc setup. is that possible for our cars considering needed mods to the rear end of business.
i looked up evo history and see that evo 4s and up came with ayc then acd came into the fold at evo 7. so the ayc was an older and more reliable setup for many years before acd came into play.
what im trying to do is get a used evo 7 helical lsd, and put in a super ayc from an older evo 7-6. what do you think as a setup?
Old Aug 17, 2010 | 09:53 PM
  #122
R/TErnie's Avatar
This is with TOO much rear camber. FYI. Also my damper suck I know.
Old Aug 17, 2010 | 10:08 PM
  #123
kyoo's Avatar
ayc doesn't fit in usdm cars. i literally dont know of a single usdm evo that's swapped in the ayc system. from what i hear from europe, aftermarket mechanicals in application work just as well
Old Aug 17, 2010 | 10:10 PM
  #124
adnmoh1's Avatar
this video explains what i want to do to my car check it from 6 minute mark and the car i want to setup as similar to is the puma lancer.
http://www.youtube.com/watch?v=0YJ-9GE0Re0
Old Aug 17, 2010 | 10:15 PM
  #125
kyoo's Avatar
read above post - ayc doesnt fit on our cars.
Old Aug 17, 2010 | 10:16 PM
  #126
kyoo's Avatar
so you were understeering with the set up? i didn't think half a degree of camber in the back would make that much of a difference
Old Aug 18, 2010 | 04:26 AM
  #127
Toxin's Avatar
Half a degree of camber is huge. Rare people understand that suspension geometry is measured in tenths and hundreds just because the amount of impact minimal changes can have...
Old Aug 18, 2010 | 06:29 AM
  #128
TommiM's Avatar
Originally Posted by WRC-LVR
Have you tried a touch of toe out in the rear say 1/32 total toe out? I d be interested in hearing about that. I would not recommend that for high speed trackwork though.
I agree with the statement 1.5 neg camber is too much in the rear. Mines is set at -1 with zero toe now. And I backed off the 25mm progress adjustable bar to full soft. Car just works better IMHO
Thats good for autox to help the car rotate. It will make the rear really unstable aat highway speeds or track events. I wouldnt recommend it for anything but autox.
Old Aug 18, 2010 | 07:50 AM
  #129
kyoo's Avatar
right, i was just kind of surprised since i've been running close to that and i haven't had any issues with my set up - especially since our diffs let us apex/power oversteer so much better now
Old Aug 18, 2010 | 07:55 AM
  #130
R/TErnie's Avatar
Yeah it screwed up corner entrance, steady state cornering, AND corner exit.
I had the car dialed in practice, but decided I wanted to make a change. I thought I was putting right back where it was...when I called the alignment shop to check what it was before we made changes... it was at .7 degrees of camber.
Old Aug 18, 2010 | 08:00 AM
  #131
kyoo's Avatar
weird.. i just paid for an alignment but maybe i'll have them do it again
Old Aug 18, 2010 | 11:42 AM
  #132
GG06MR's Avatar
I recommend the Lifetime alignment at Brake Check for $120~. I've had my car aligned 3 times now, two times to my own spec, and it only costs me $3~ in tax each time I take it in now.
Old Aug 18, 2010 | 01:31 PM
  #133
griceiv's Avatar
You have two adjustments to adjust camber and toe...and like most adjustments they are not independent, but linked together.
-1.4 is too much camber in the rear from my experience.
I ran toe out in the back...its a handfull on the freeway especially with ruts. It doesn't really help the car turn IMO...it just makes it wander and be unstable. Less camber is more predictable IMO.
there are more variables you can adjust to get the car to balance than just rear camber and toe. happy tires make more force and you're selling yourself short if you're intentionally making the tires unhappy with crappy camber.
Old Aug 18, 2010 | 02:10 PM
  #134
donour's Avatar
Ha! I've seen you guys drive. How can those tires possibly be happy?
other news::
My shep diff arrived yesterday and I installed it this morning. I filled it with OEM diaqueen. As I pulled out of my driveway for a test drive, noise consisted of:
*CLUNK*
*Clunk*
*...clunk*
>>SILENCE<<
I can't hear anything coming from back there in tight figure eight turns. I still have the OE bushings and brackets. My test drive only lasted 5 minutes. I had to park the car or I was going to get myself arrested! It's too easy and too much fun to drive the car sideways down neighborhood roads. It's _insanely_ easy to handle.
caveat: I have zzyzx coilovers with beefy springrates (>15k).
I'll post a real review after this weekends divisional solo event.
d
Old Aug 18, 2010 | 02:56 PM
  #135
shuttlegoose's Avatar
cant wait to hear your review!
