Rear Diff Options - Power Oversteer Found Here
Old Aug 11, 2010 | 06:52 AM
  #91
revvin9k's Avatar
Okay, i'll chime in here. While I do not track my car as most do here, I do put her through her paces.
I have the TRE 1.5 rear diff upgrade. I initially got it tring to chase down a de accel noise, so I just upgraded the rear diff.
I could'nt say I really noticed a real difference until I completed my suspension.
I have the full Whiteline catalog on my car, PSRS, Perrin rear bar on the middle setting, Perrin end links, stock front sway, MR Bilsteins with Swift Spec R's, GT Spec trunk cage, Carbing strut bar, -2.5 in front, -1.3 on the rear, 0 toe all around.
After finishing her all up just this week....... taking turns has NEVER been so fun.
The best way to describe it is.... the rear tires feel like they are on wheel dollies going around turns hard. It is such a good mod it's unreal.
I'm no nut swinger, so if you choose, TRE, Shep, Cusco etc, it would work all the same. I am nothing short of ecstatic.
A must have for any Evo. Period.
Old Aug 11, 2010 | 07:05 AM
  #92
Evo8RA's Avatar
I've been using the Cusco 1.5 for the past several years at the recommendation of Mark Daddio. It works well as many of the alternative solutions do, as described in this thread. If I were doing it today, I'd go with the Shep conversion because I've also had success and extreme reliability from my Shep built trans & front diff and it's much less expensive.
One thing I can add about my Cusco is that it REALLY didn't like Redline Shockproof Heavy. I used this fluid with varying amounts of LSD friction modifier for the first month. Taxi-ing around the pits in tight turns was very noisy, making crunching noise that sounded like the diff was eating itself up. I changed the fluid to Mitsu Diaqueen LSD oil and within 200 feet of driving ALL noise was gone.
Old Aug 11, 2010 | 07:19 AM
  #93
kyoo's Avatar
Thanks - I'll keep that in mind - my cuscos fairly new but I havent had any noises yet. I've been using amsoil svg gear 75w90 with some friction modifier. like I stated before, will probably switch to 75w110. Did you have the diff properly shimmed etc? I heard that's a must for these diffs.
I noticed you have a X too - I'm sure the cars are completely different, but is it any comparison to the ayc?
Old Aug 11, 2010 | 11:10 AM
  #94
donour's Avatar
Mark,
Thanks for the info on fluids. If memory serves, the cusco was the only option back when Daddio built his SM car. My diff is sitting at Shep's shop right now. I'll let folks know how it does, competitively, in a few weeks. I have loads of data on my car as well as some pretty good local benchmarks.
d
Old Aug 11, 2010 | 11:12 AM
  #95
donour's Avatar
FYI: Mark Berry's Evo 8 has 1000 lbs stripped out. That's no typo -- 2200 lbs. Comparing to a X might be tough.
Old Aug 11, 2010 | 11:16 AM
  #96
kyoo's Avatar
Originally Posted by donour
Mark,
d
very nice - i do believe daddio compared the two diffs at one point, and that he prefered the cusco - though the differences are probably minor. keep us updated on how the car handles with the new diff!
Old Aug 11, 2010 | 11:23 AM
  #97
kyoo's Avatar
ah probably right on that one.. i guess was just curious how the diffs compared
Old Aug 11, 2010 | 11:37 AM
  #98
R/TErnie's Avatar
FYI,
Jon @ TRE said the diff would get quieter after a few more miles. I just changed the fluid in the diff last night
Old Aug 11, 2010 | 12:01 PM
  #99
kyoo's Avatar
Originally Posted by R/TErnie
FYI,
Nice, what fluid did you go with this time?
Old Aug 11, 2010 | 12:10 PM
  #100
R/TErnie's Avatar
Redline 75/140 NS
no friction modifiers
Old Aug 11, 2010 | 08:48 PM
  #101
kyoo's Avatar
Redline 75/140 NS
nice - post some vids when you get a shot
Old Aug 11, 2010 | 08:52 PM
  #102
R/TErnie's Avatar
Friday We'll have some in car video and some external shots for sure.
Old Aug 12, 2010 | 03:09 PM
  #103
Galant VR-4 #34's Avatar
The most noticed mod I have ever done to my car to help me rotate the rear was the TRE 1.5 mod. I cant speak for the others but it has performed flawlessly for more than 2 years. I recently sent it back to Jon just for a check up since I abuse them so much and he said nothing needed to be done and sent it back. We are talking 40 minute road races with Big sticky Hoosiers and absolutely no issues. It has also helped me save my front left tires allowing me to run A compounds. Prior to the TRE rear, I had to run Rs to have them last the whole race. Now I get two full races out of 1 set of As. the other benefit is you can do a lot more steering with the throttle allowing you to open your hands up = more speed and better tire wear.
Marty
Old Aug 12, 2010 | 07:27 PM
  #104
kyoo's Avatar
Marty
Old Aug 12, 2010 | 07:35 PM
  #105
R/TErnie's Avatar
Marty
Well said Marty!
i would like to second the fact that it SAVES your front tires.
