Best Recirculating BOV for 35+psi
Old Jan 31, 2010 | 09:34 AM
Drill_Sergeant's Avatar
Veteran: Army
stock metal valve with no issues
Old Jan 31, 2010 | 09:55 AM
ssg_petty_210's Avatar
tial now has a recirc bov. Thats what im going with
Old Jan 31, 2010 | 10:04 AM
tristat3's Avatar
from what ive heard synapse hold boost very well
Old Jan 31, 2010 | 10:09 AM
Trojan man's Avatar
synapse will hold whatever you can throw at it (more than the 31psi that i see atleast). I get some surging issues with my setup but no flutter at all. Stock 9MR DV fluttered and leaked like it was it's job at anything above 26-28psi
Old Jan 31, 2010 | 10:23 AM
Ted B's Avatar
What you've heard is verifiably correct. We know this to be true because we've pressure tested them to 40psi. If they didn't hold up 100%, there is no way I would consider using it or recommend it to others.
I want to make a point to all those who read this that one has no way of knowing that something 'works fine' unless he has actually static tested the BOV to a pressure at least that seen under real-world conditions. So far, I have witnessed several BOVs that were reportedly 'just fine' until a pressure test revealed that not to be the case, much to the individual's surprise.
That being said, I can almost guarantee you that at least one person in this discussion has a BOV that is leaking air at the operating pressure and they are unaware of it.
Old Jan 31, 2010 | 10:30 AM
aka.ralliart15's Avatar
I ran 35psi on the APS no prob, now im running a Tial Q and loving it. Still on MAF too, my driveability is perfect.
Old Feb 2, 2010 | 11:10 AM
Synaptic Evo's Avatar
Originally Posted by Ted B
FWIW, I have pressure tested the Synapse unit to 40psi, and it absolutely will not leak.
Ted we have tested the blow off valve to 140PSI with NO leaks
and it can go much higher
Old Feb 2, 2010 | 01:42 PM
project_skyline's Avatar
I have APS twin vent as well, its help 36 psi no problem.
The new tial QR is also a nice recir BOV.
Old Feb 2, 2010 | 03:01 PM
Teal2nnr's Avatar
I use a Forge, but havent been as high as 35 psi yet.....
Old Feb 2, 2010 | 05:31 PM
bbyevo8u's Avatar
hows the drive driveability with the APS??
Old Feb 2, 2010 | 05:45 PM
STIKILLA1084's Avatar
who sells the synapse bov?I keep hearing good things about it.
Old Feb 2, 2010 | 05:47 PM
ErikB's Avatar
APS Twin Vent!
Old Feb 2, 2010 | 06:13 PM
PhoPoweR's Avatar
Synapse
Old Feb 2, 2010 | 06:21 PM
tim85851's Avatar
im stuck between the aps or the synapse bov...i recommend either...since ive read up about both and both seem fine...i hear a lot about which ports to connect on the synapse though...which is why im pointing towards the aps more...
Old Feb 2, 2010 | 06:30 PM
bbyevo8u's Avatar
^^ lol me too
