Quote:
As far as the 24.5 slick vs 26" slick question. I'd run a 26" and high rpm until the car started to drift around at the topend because of the tall tire. The tall tire and high hp can start to become a handful at high speeds. IMO , less then 140-150 traps a 26" should be fine.
If the car is drifting around a lot you could change to a 4.11 and a 24.5" slick and the car should drift around less with the short sidewall.
Once you start making serious power and have a longer power band you will see higher traps being able to ride out 4th gear. That's just the way it is. Max your Red out with a 38PSI spike and boost it keeping it in 4th. But yeah big big turbos will gain.Originally Posted by Abacus
I also thought this but proved the opposite. Slowed the car down. I have a red now and it does spool 20psi by 3600 in 3rd on the street/dyno so it does help spool.As far as the 24.5 slick vs 26" slick question. I'd run a 26" and high rpm until the car started to drift around at the topend because of the tall tire. The tall tire and high hp can start to become a handful at high speeds. IMO , less then 140-150 traps a 26" should be fine.
I have the six speed so I get better ratios on the highway.
Had the 4.11 on a 2.3 , 6262,6765 and I loved it I thought it was perfect for street use
and some weekend track fun.
and some weekend track fun.Evolved Member
Quote:
I agree with you on that one, I hated the 4.11. Harder to launch, slower traps, tears up clutches quicker etc. I moved back to the stock gearing and will never do that again.Originally Posted by 94AWDcoupe
really doesnt get any clearer than that. I have been telling people for ten years the 4.11 is a mistake and that it positively makes the car slower. yet no really backs me up. maybe they will believe your feedback.
Abacus
close
- Join DateJun 2012
- LocationFL
iTrader Positive Feedback100
iTrader Feedback Score(9)
Liked:418 Times in 270 Posts
The 4.11 paid off for the half mile run at 500whp. 8500ish in 4th was 149.70 on a 25" tire. Originally Posted by High_PSI
Once you start making serious power and have a longer power band you will see higher traps being able to ride out 4th gear. That's just the way it is. Max your Red out with a 38PSI spike and boost it keeping it in 4th. But yeah big big turbos will gain.I have the six speed so I get better ratios on the highway.
Shooting for around 650 whp / 500+ tq. Going to be running an FP Black on a Buschur 2.3 RPM motor on e85.
Edit: Forgot to mention I already have a Shep trans with an Evo 9 first gear and every option they have except the Evo 9 5th and final drive upgrade.
I'm on the fence about getting a 4.11. Anyone have any further advice if this will be worth while for me to get?
Thanks
Thanks
Any advice?
Thanks
Originally Posted by Insanity Evo
Shooting for around 650 whp / 500+ tq. Going to be running an FP Black on a Buschur 2.3 RPM motor on e85. Edit: Forgot to mention I already have a Shep trans with an Evo 9 first gear and every option they have except the Evo 9 5th and final drive upgrade.
Thanks
if you dd your evo while living in a hilly area, i highly suggest staying with the stock f/d.
i have a 2.4L 4.11 with a evo9 1st & I live in a hilly area & my clutches hate it. i have warped my exedy twin & the stench that comes from my comp stg 2 disc smells worse than anything imaginable. anything flat, doesnt matter, but if i get caught on a hill / slight incline, forget it.
before that, i had a 2.3 with an oem 5spd... i miss the evo 8 1st gear with the 4.53, same area = no problems.
i will be pulling my engine & gb soon & will be going back to 4.53 & evo 8 1st gear.
How much power are you putting down and which turbo?Originally Posted by Aby@MIL.SPEC
if you dd your evo while living in a hilly area, i highly suggest staying with the stock f/d.i have a 2.4L 4.11 with a evo9 1st & I live in a hilly area & my clutches hate it. i have warped my exedy twin & the stench that comes from my comp stg 2 disc smells worse than anything imaginable. anything flat, doesnt matter, but if i get caught on a hill / slight incline, forget it.
