Heater does not feel hot.
Old Feb 8, 2010 | 01:14 PM
xpehbam's Avatar
When I turn the heater on it does not feel as hot as it use to. And it blows cold air on the middle setting. What could that be?
Old Feb 8, 2010 | 01:15 PM
detroit pistins's Avatar
thermostat
Old Feb 8, 2010 | 01:16 PM
Smike's Avatar
Or heater core or cable issue.
Old Feb 8, 2010 | 01:33 PM
chad99evo's Avatar
i call that year round a/c
Old Feb 8, 2010 | 01:42 PM
xpehbam's Avatar
LOL
Car gets hot as usual, so probably not thermostat. How can I check the cables? Also my coolant was low after the clutch install but I topped it off
Old Feb 8, 2010 | 02:24 PM
Lumpskie's Avatar
Try burping your coolant
Old Feb 8, 2010 | 02:45 PM
batty200's Avatar
The coolant is still low and you need to fill it up.
Old Feb 8, 2010 | 02:52 PM
MitsuJDM's Avatar
Unlikely, but worst case it could bve a bad headgasket.
Old Feb 8, 2010 | 04:40 PM
hempele28's Avatar
Check the cable on the heat control. They are known to snap. I am dealing with one now.
Old Feb 8, 2010 | 05:41 PM
EvolutinIX's Avatar
Incorrect mixture of water and anti freeze, add more water.
Old Feb 8, 2010 | 05:46 PM
v-manracing's Avatar
probally your coolant, make sure the mixture is right around 50/50, make sure you get all the air out. good luck
Old Feb 8, 2010 | 05:56 PM
badev0's Avatar
Mine does the same thing a lot. My cable is messed up so once in a while I have to manually reach under the dash and turn the lever for the heat door or w/e.
Old Feb 8, 2010 | 05:59 PM
buchnerj's Avatar
This. Mine only came unhooked from the control behind the dash, but apparently it had been like that for some time. I bought the car new, but I think it came off when I installed my touchscreen head unit. I thought the heating in the car sucked, but a local mechanic said it shouldn't be this way, looked under the dash and fixed it in like 5 minutes if that.
It is breathin' fire now.
Good luck
Old Feb 8, 2010 | 07:17 PM
05ah8james's Avatar
Is the heat cooler all the time or just when idling?
