Kelford 272 idle and drivability
Old Feb 10, 2010 | 07:18 PM
adWRXi's Avatar
to you guys out there with kelford 272s, hows drivability and idle?? stop and go traffic? stalling?
i have an 03 w/ ix turbo that drives perfectly with hks 272s but i really.. really.. want kelford 272s, but i cant determine what would happen to drivability because there are so many mixed reviews out there. some input would be appreciated.
Old Feb 10, 2010 | 08:13 PM
scheides's Avatar
EvoM Moderator
do it. I've had mine for a year and a half now, great cams for a DD evo!
Old Feb 10, 2010 | 08:46 PM
mak1000's Avatar
kelford is a more aggressive cam. i recently installed 280 kelford cams in my car and the idle is kinda bad but thats what happens when you go with a cam that has more lift and duration. the stock ECU will eventually learn some what and adjust to where the drivability is better but dont expect to have the same drivability as stock with kelford cams. just not going to happen in my opinion. if you want to go faster then get the kelfords. hope this helps you out?
mario
Old Feb 10, 2010 | 09:29 PM
LG_4g's Avatar
Ive been running Kelford 272s for about 8 months now. Great cam.
They gave me a nice top end with my 9 turbo.
Check out my graph:
https://www.evolutionm.net/forums/ev...e85-29psi.html
Old Feb 10, 2010 | 09:31 PM
adWRXi's Avatar
Check out my graph:
hows drivability?
Old Feb 10, 2010 | 09:35 PM
LG_4g's Avatar
Driveability is just like stock. No stalling, sputtering, or abnormal idle.
However i do have a 9 though. Ive been told that the loping can be tuned out on a 9.
Old Feb 11, 2010 | 08:39 AM
jid2's Avatar
They require a good tuner. They need some more timing at idle, and adjustments to the idle tables in the stock ECU. After that they are totally fine - without those tweaks the car dies at idle once it's warm.
If you can "search" this has been covered once a month for years now. I've actually posted my ECU idle tables in a thread asking this same question.... go forth and search.
Old Feb 11, 2010 | 08:50 AM
4RETECH's Avatar
I like them. They came highly recommended and they are great.
Of course, yes, you have to get a good tune to get it to not stall at idle.
I have a buddy who put them in and he had his car dyno tuned at some local shop, amazing power at top but when he comes to a light it stalls. I told him to retune and he refuses.
I was going to get the HKS 272's, but Kelfords are the way to go esp. if you are looking into a turbo upgrade in the future.
manthny18
Jan 25, 2017 10:27 AM
av00va
Sep 14, 2014 04:19 PM
real fast
Aug 12, 2014 05:33 PM
EVO8LTW
10
Oct 28, 2011 12:53 PM
Kracka
30
Dec 19, 2008 06:06 PM
