David Buschur's RS/BADBISH 2010 build
Old Feb 19, 2010 | 02:16 PM
  #121
cesare77's Avatar
Can't wait to see it at the track nice and clean
Old Feb 19, 2010 | 02:24 PM
  #122
Philthy748's Avatar
Originally Posted by davidbuschur
I put the car back how it was, HTA86 and the BF272 cams. I am not willing to accept a loss in the low/mid range unless there is SUBSTANTIAL gains up top and even then it's tough..
You're starting to sound like a twinscroll guy now Dave - lol
Old Feb 19, 2010 | 02:40 PM
  #123
David Buschur's Avatar
philthy, not quite cause the twin scroll stuff I've seen lose it up top.
Old Feb 19, 2010 | 02:50 PM
  #124
Philthy748's Avatar
I'm joking with you Dave...
I think you and many others need to see a lot more testing/results before you would be willing to revisit twinscroll...
Congrats on another sick build...
Old Feb 19, 2010 | 03:41 PM
  #125
psphinx81's Avatar
where is the video!! ugh hahaha
youre killing me jarrod!
Old Feb 19, 2010 | 04:32 PM
  #126
Video on Monday.
Old Feb 20, 2010 | 09:48 AM
  #127
Ted B's Avatar
... I have stated before in the past my feelings on twin scroll set ups. My thought has been that the smaller runner tubing hurts the power at high horsepower levels. Ron and I both thought that this test would result in some very good gains in the low/mid range power, which the gains are substantial enough to justify the header on a car that isn't looking to run 8's like mine.
Informative test, thanks for that. It's logical to guess that the smaller diameter primary will be 'too much of a good thing' at some power level, and now we know roughly where that point lies. IIRC, the figure Geoff quoted off the top of his head as the threshold of one or the other is in the general vicinity of what your test revealed.
As you know, evodan2004 has a TS HTA3586 with the smaller diameter primary tubing, while my TS HTA3582 has the larger diameter. From what I can tell in comparing our 93 octane info, the difference is right about exactly enough to offset the difference in spool between the two turbos.
Good stuff!
Old Feb 20, 2010 | 09:54 AM
  #128
scorke's Avatar
Originally Posted by awdwannabe
Hey Dave, just after reading through the entire thread and seeing the differences between the small and large runners, have you guys thought of taking a look at the idea of having different internal runner area? Basically if you've ever looked at a two stroke quad or bike, about how the exhaust diameter is small when it first comes out, then expands then contracts. With this theory, you would get the stronger bottom end benefits your looking for with the smaller runner, and the top end performance with the expanded internal area.
Could be just some stupid thought, or just what you need.
They are 2 stroke, and when building two stroke exhausts the pressure inside the exhaust pipe, at the exhaust tip, and at the exhaust port all need to be carefully tuned so that you do not run into restrictions at certain rpm points, lots of sonic tuning not relative really to turbo cars...
Scorke
Old Feb 20, 2010 | 11:02 AM
  #129
foxmr's Avatar
good to see all of the testing.... now thats dedication
Old Feb 20, 2010 | 12:12 PM
  #130
scheides's Avatar
EvoM Moderator
Ooh idea, for ya dave! Variable diameter exhaust manifold tubing! Tie it to the same switch you use for your dual-stage MBC. At low boost, it uses the smaller tubing, at high boost it uses the bigger tubing! Genius! I'm sure implementing it will be no problem
and hey, you missed my note at the top of the last page: take this thing down the track yourself a few times this year, just for fun!
Old Feb 20, 2010 | 12:24 PM
  #131
scorke's Avatar
In some crazy diesel applications they do this by having the second volute of the turbine closed off so at low RPMs it's acting as a single scroll super small volume turbo and at high RPMS its acting as a large volume twin scroll unit, very cool.
Scorke
Old Feb 20, 2010 | 02:01 PM
  #132
R/TErnie's Avatar
Dave you need to make some passes this year!
Did you end up advancing the camshafts and playing with cam timing?
Have you thought about putting a MIVEC head on your car to help spool up even more?
VGT turbocharger?
E85 makes a big difference in spool up time as well! Test it vs. C16 or Q16. I'm sure Crispeed has done his own testing on this.
THANK YOU DAVE! I loved the TS results. I'm super stoked that you tested it, even if you didn't believe in it... shows that you're open and willing to try anything if it makes the car faster. Big thumbsup.
Old Feb 20, 2010 | 03:34 PM
  #133
Conrad's Avatar
Great results David, be sure to update the MLR thread in the UK
Old Feb 20, 2010 | 04:33 PM
  #134
akauf's Avatar
Scorke
I just saw this sort of spool valve being used on a 2jz. A twin scroll housing on an open maifold with a valve closing the "inner" volute until a boost pressure. The guy was claiming some serious spool up gains with little or no loss up top. I'm interesed to see more testing with these.
Sounds like your making great progress here DB. I'll be following this re-build for sure
Old Feb 20, 2010 | 07:50 PM
  #135
dabeast's Avatar
i cant wait for the vid! 2 more days though lol
