ACD Tuning Options - USDM CT9As, Read!
Old Nov 30, 2011 | 10:18 AM
  #136
DaveK's Avatar
Originally Posted by kyoo
It would be interesting to see how much performance benefit the MoTeC can result in the end over a flash like ACD-Tuning for the cost. I think the biggest benefit will have to be the custom map for a specific track and driver - otherwise everything that can be tuned by the MoTeC should be able to be tuned by ACD-Tuning, correct?
I think the big difference is the MoTeC is end-user adjustable. While the initial cost of the MoTeC, Gems, etc are higher, I can tweak to my hearts content. I played the exchange rate game and found a race shop overseas willing to ship me a MoTeC box for much less than vendors charge here in the US...I think it set me back $1350 or so. Sometimes you'll find people willing to share a map, and you can load that into the box, drive around and see if its to your liking. Say you love the way the car handles 50mph and under turns, but like the way the supplied maps handle above that speed? Simple, just cut and paste the boxes to come up with a new map, then try that out as well.
Pre-made options are great for the folks that don't want to tinker around, or who tend to run with common setups in road race, auto-x, etc. environments. You can drop $500 or so and have a few maps to switch between. I'd assume if you wanted to try additional maps, you'll have to ship your ACD box back to get re-tuned, and then go out and try again, all adding to the cost of the initial $500.
Dave
Old Nov 30, 2011 | 10:30 AM
  #137
kyoo's Avatar
Dave
Exactly.. Also, especially when you consider auto-x, in which the actual course is different every event and you only get 5 cracks at it, it's simply better to go with a map that is setup for auto-x in general and is gonna outperform stock - that's pretty much exactly what you need.
$1350 is killer..
Old Nov 30, 2011 | 02:44 PM
  #138
kyoo's Avatar
Originally Posted by discogodfather
You have a good point in that the reading of the physics in the papers raises some simple points about how precarious the torque vectoring effect is on the "positive" side of the handling. They imply that it can easily work against you.
The physics are more understandable for me on the ACD, since influencing the handling of the car through the center diff seems more straightforward to me too, the parameters are broad. Torque vectoring seems to have a very narrow sweet spot.
Exactly. I can't imagine how difficult it must be to find optimal lockup for each varying situation, and I can't imagine that optimal for one situation will be the same for another..
I would think it also forces the driver to be aware of all the inputs that the AYC is reading and how it will react in order for the driver to get the most and optimum When the ayc is reading so many inputs that the driver isnt even aware of he may do things that put in input that may be "wrong" for the optimal situation. ie if the driver tries left foot braking, but that new input changes the output of the AYC which isn't optimal for the condition, etc etc etc..
There definitely is potential, but as you said that sweet spot is probably very narrow and very difficult to find. IMO, very complicated stuff. Changing the output for one set of inputs could potentially make it worse for another very similar set of conditions! What creates a perfect slip angle for one exact condition may create too much oversteer for another very similar condition -
Old Nov 30, 2011 | 06:01 PM
  #139
lan_evo_mr9's Avatar
And this is where the almighty compromise comes in
You can absolutely make yourself go crazy trying to find the perfect setup, the perfect tune, the perfect what ever. You can come very close for sure, as long as you are focusing on one facet of racing. This is why we offer the maps we do- it is a simple and very effective solution for guys who race autox, circuits, rally, etc. The basic maps we provide are EXTREMELY good at what they are meant to do- sure you might find a 10th or two with some on site tweaking, but let's be real here.
Dave,
When it comes down to it, the stock acd unit is just as effective as an aftermarket one as far as tune ability. It may not have the limp mode feature, but it is effective in dropping times in any facet of racing- that's a fact. It may also be a bit harder to tune due to 7 maps vs motec's 2 maps, but that is where I come in. I don't think that I will have a customer that would ship his acd unit back to me multiple times- if it came down to that, I would honestly stop charging at say...$1350 If I did have a customer that required multiple maps for all sorts of racing or just wanting to perfect one facet, I would recommend 2 acd units that you could just swap out.
Matt
Old Dec 1, 2011 | 09:42 AM
  #140
kyoo's Avatar
Dave,
Matt
I agree - I think the cost of MoTeC and that very same end user customization is probably overkill for even most track evos. Personally I don't even want that level of adjustment. I don't have the hours or the mastery of physics to optimize this kind of thing. I just wanna tell the car okay, I'm on a track, optimize lockup for higher speeds, or I'm autocrossing, optimize for lower speeds. Let the pros deal with the programming. Same goes for an engine tune - I don't want to tune the car myself, I want a professional to do it.
Old Dec 1, 2011 | 09:55 AM
  #141
Kevmac3685's Avatar
subscribed
Old Dec 1, 2011 | 10:26 AM
  #142
DaveK's Avatar
Please note the MoTeC MDC comes with 4 tunes that are better than the factory maps and are expeically different in the LFB'ing realm. This means if you don't want to mess with them, you don't have to. FWIW, I've run those supplied maps for 3 seasons with the car and it wasn't until this summer that I started playing around with things...when I had time to do some back to back testing. I really want to invest in a traqmate to actually try to quantify gains/losses.
On a strictly economic basis, there's no need to consider using the MoTeC MDC now that guys like Matt are offering flashes for road racing and auto-x. Once (or if?) he starts looking at gravel and snow maps, that'll pretty much negate the need for a MoTeC for all but the most serious (read: big budget teams with development time) efforts.
Ain't technology great!
Dave
Old Dec 1, 2011 | 12:07 PM
  #143
Dave
Dave,
Thank you for your kind words- I think we had a great discussion about the two relevant options out there right now. We do offer maps for gravel and snow by the by
I agree with you on the big budget team stuff- if they are doing such serious hard core racing- stuff is gonna break and the limp mode feature alone could save the day for them.
Matt
Old Dec 1, 2011 | 12:25 PM
  #144
DaveK's Avatar
Just curious - is there any reason you couldn't program one of the settings to do the full lock thing? Sure, you'd lose one setting, but for someone running a stage rally event, you could do a gravel setting, a muddy setting (similar to snow maybe?), and change the spot for tarmac to be full lock. Of course I'd need royalties.
I think one thing that would be really cool for the techies to see is datalogging info related to vehicle speeds before and after the ACD tweaks. I'm not thinking the ACD code or any proprietary data, more something like Traqmate data showing differences.
Dave
Old Dec 1, 2011 | 12:28 PM
  #145
L888Apex's Avatar
I recently got the OEM USDM modified to what it should be, after I get used to that set up, i'll most likely be doing this next Definitely a great write up, and i'm anxious to try it out
Old Dec 1, 2011 | 12:32 PM
  #146
SyZyGy1394's Avatar
You talking about re-arranging the rear diff plates and discs?
Old Dec 1, 2011 | 03:13 PM
  #147
Dave,
The stock acd mod is capable of doing full lock all time if need be. Your staged rally map idea is no different than our 2-3map circuit idea (perfect map for each turn approaching). But I will definitely give you royalties because I'm nice
Matt
Old Dec 1, 2011 | 06:38 PM
  #148
L888Apex's Avatar
oops forgot to put "diff" in, yes the stock diff
Old Dec 2, 2011 | 02:25 PM
  #149
kyoo's Avatar
what rear diff did you go with? And which ACD tune?
I think rear diff + acd tune is the perfect combination for CT9As to really unleash its full potential. ACD tune will send more torque to the rear for corner exits and the rear diff will send more torque to the outside wheel.. There's really potential for unreal exit speeds. I may even consider running a front sway bar next
Old Dec 2, 2011 | 03:30 PM
  #150
Front sway bars are a great mod IMO. It really helped my setup with bump steer and stability.
Matt
