ACD Tuning Options - USDM CT9As, Read!
I installed the ACD TUNING STREET MODE of Gruppe-S, i run on Hill Climb and i am very happy with the results, less understeer on low and high speed corners. Some suspension modes could help to reduce a lot the understeer too.
i SHOULD be heading out to autocross next weekend for the first time since my old turbo let go - eager to try out the acd flash and see how the green performs compared to the hks - though i can already say its MUCH laggier
Anyone have any pics of the ACD controller installed? Service manual says passenger kick panel, but online seems to say it's under the dash.
Can anyone confirm?
Can anyone confirm?
Was waiting to hear more from people on this but decided to bite the bullet anyways cause even if it gives me 0.5sec/60sec course, itll be worth it.
I do 30ish events a year so hopefully I can give some good feedback. Im pretty consistent in my PAX placing so Ill know if this is making me fast or not pretty quick.
Instructions are here:
http://www.acd-tuning.com/acd-removal.html
You need to take out the kick panel and the glove box. The you can access the ACD ECU that is held with two rubber bits and one bolt against the side of the inner fender area. It's a bit fiddly but extremely easy to do.
Awesome, thanks for that. That is exactly what I need.
I pulled off the kick panel and was perplexed that I couldn't find it. I should have just looked up from there.
Curious on update. Were you able to go autox and test out the acd flash?
