Max TQ on Exedy Twin HD
Old Apr 22, 2010 | 08:29 PM
  #61
xRoguex's Avatar
Originally Posted by SavEVOIX
Out of curosity, how long do you guys think it takes for the discs to "cool" I'd imagine a couple minutes and it'd be fine.
Inside a hot trans, next to a hot motor.
15-20 mins?
Old Apr 22, 2010 | 08:59 PM
  #62
rgar's Avatar
so... 2 good launches back to back and you've ruined your clutch? I thought by having two discs you were distributing the heat and they were supposed to hold up better?
Old Apr 22, 2010 | 09:01 PM
  #63
xRoguex's Avatar
disks are thin - and there for do not disipate heat.
what you have done - is double the friction area - this is the reason people move to twins/triples..
more friction area = more tq capacity.
Old Apr 23, 2010 | 12:33 PM
  #64
Svendiesel's Avatar
Ya I plan on giving it about 20 mins between passes, I usually do this anyway to give everything some time to kinda relax lol. Its all in my head.
Old Apr 25, 2010 | 02:20 AM
  #65
burnzy's Avatar
Originally Posted by Svendiesel
Welllllll, I have the HD Twin sitting downstairs on top of my Sheptrans box. I have some thinking to do before I get to installing everything. Do I chance it with the twin hd, or just go for the SR Triple disc? Keep in mind Im doing a Red and will be at 32+ psi, goals are to break into the 10's and trap around 130.
I think the SR Triple would be overkill, but upgrading the Twin HD to a triple would have the benefit of using the Twin HD's pressure plate, which has less clamping force than the SR Triple disc's pressure plate.
So for example, and this isnt smack on data, but just to show what I mean...the Twin HD holds 450 lb/ft, the SR Triple holds 570 lb/ft, and a Twin HD upgraded to a Triple disc would effectively hold somewhere around 500lb/ft due to the extra disc in the system but still on the Twin HD's pressure plate.
So that seems like a nice middle man. Which is almost why I want to put my twin HD for shats and giggles, see what happens, and then upgrade if I have to.
actually you might find the SR triple has the same clamping load as the twin SD, same pedal pressure, only reason the sr triple holds more than twin HD is due to the extra plate. putting the twin hd cover on a triple would pretty much turn it into a triple HR i'm pretty sure.
Old Apr 25, 2010 | 06:56 AM
  #66
mrboost05's Avatar
^^ fyi the twin hd i bought was from a car with a red on it making alittle over 500whp and that thing was toasted in no time he said. those larger stock frame turbos are not easy on the the clutches by any means i bought his and upgraded to a tripple as soon as i had the cash y put it all back togther just to have to take it back apart.
Old Apr 25, 2010 | 01:08 PM
  #67
Svendiesel's Avatar
Hmmmm....interesting. I was unaware the clamp load of the SR pressure plate was equal to the SD's.
The more I read this thread the closer Im getting to sending back the twin and get the SR Triple
Old Apr 25, 2010 | 08:47 PM
  #68
SPECJUNK's Avatar
so who can get the parts necessary to go from a triple carbon to a triple cere-metallic, and if a quartermaster tob will work, convert it to a push type pressure plate, since i need to score a not so broken pressure plate any how.
any ideas?
Old Apr 26, 2010 | 07:36 AM
  #69
Svendiesel's Avatar
AMS pieced together their own Push conversion for the Exedy clutches, they sell both the whole kit as well as an upgrade with a new pressure plate http://www.amsperformance.com/cart/A...mance.com.html.
Old Apr 26, 2010 | 07:55 AM
  #70
Poloiceberg's Avatar
Not to thread jack but didnt turbo trix make a clutch fork stop to remedy the tob problem. Has anyone broke a tob clip with the fork stop installed? It seems alot better than paying 1300 for and conversion kit from ams.
Old Apr 26, 2010 | 08:30 AM
  #71
Svendiesel's Avatar
A bunch of places sell the fork stops. I bought mine from STM.
Old Apr 26, 2010 | 08:32 AM
  #72
buchnerj's Avatar
Same here. It works just fine. I have yet to hear a clip pop off with people running a fork stop. It should be a good remedy, 0 issues so far.
Old Apr 26, 2010 | 08:36 AM
  #73
INEVOIX's Avatar
Zero issues on mine
Old Apr 30, 2010 | 05:04 PM
  #74
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Where are you guys getting your Exedy Twin HD clutches from?
Old Apr 30, 2010 | 05:36 PM
  #75
xRoguex's Avatar
MAny Places sell them...
Migsubishi
12
Dec 29, 2015 12:49 PM
badev0
Sep 2, 2015 06:06 AM
alenewit3928
28
Nov 21, 2014 12:59 AM
Don Q
23
Jan 10, 2011 03:37 AM
BlueFish
Nov 11, 2006 02:20 AM
