Surprise...Surprise (spark plug content)
Old Feb 19, 2010 | 02:38 PM
850RCT9A's Avatar
Fixed!
Old Feb 19, 2010 | 03:23 PM
czilla's Avatar
did u change the plugs, if so how is it running?
Old Feb 19, 2010 | 04:08 PM
awd2gen's Avatar
I had a plug like cylinder #2 from piston slapping it.
Old Feb 19, 2010 | 04:15 PM
FL_SilverEvo8's Avatar
+1
Old Feb 19, 2010 | 04:17 PM
Kracka's Avatar
How many miles on the plugs? Those are not the correct plugs for a IX (which you have listed in your profile)...hopefully they're from an VIII.
Old Feb 19, 2010 | 04:23 PM
Sim2k's Avatar
Wow, I don't think I've ever seen a spark plug broken like that. Mine was sputtering at WOT, so I replaced the copper plugs with iridium plugs in my Evo VIII, and it's never run better. Just in case you were interested.
Old Feb 19, 2010 | 04:28 PM
Kracka's Avatar
I'm loving the iridiums in my IX!
46k miles and they still look good and performed flawlessly:
Old Feb 19, 2010 | 11:00 PM
850RCT9A's Avatar
yes i changed the plugs and it idles A LOT quieter and runs A LOT better.
im using my buddies account..i have an VIII
Old Feb 19, 2010 | 11:34 PM
churchja's Avatar
Any damage to your engine? I had the same issue as your #3 plug in which the tip broke off inside the #2 cylinder and caused some serious damage resulting in an 2.3L engine rebuild from MAP Performance.
What fuel do you usually run? Just wondering...
Thanks,
Jay
Old Feb 20, 2010 | 01:29 AM
mrfred's Avatar
You should be sticking a boroscope down into the cylinders corresponding to the grounded electrode and busted strap. More than likely there is some piston damage.
Old Feb 20, 2010 | 02:11 AM
norcalSRTrida's Avatar
unfortunately, that may not be the only damage..
Old Feb 20, 2010 | 03:16 AM
MR. EVO MR's Avatar
check for the reason before other **** happens, dont drive her like that
gl
Old Feb 20, 2010 | 04:39 AM
bbyevo8u's Avatar
omg how was your car even running with plug like that??
Old Feb 20, 2010 | 04:55 AM
0xDEAD's Avatar
Your probably going to want to do a leakdown test. Very well have cracked a ringland.
Micahsolomon02
Jun 20, 2016 02:54 PM
JDMEvoX
29
Jan 13, 2016 12:55 PM
bluedevil06
Site Feedback / Suggestions
Jul 11, 2011 10:08 AM
ihearthondas
Lancer Engine Management / Tuning Forums
Feb 4, 2008 03:05 PM
ghostrider
Jul 18, 2003 06:07 PM
