Stalls when clutch is disengaged..
Old Mar 26, 2010 | 06:28 PM
  #31
LGshow19's Avatar
Do you have an Aftermarket intake?
Old Mar 26, 2010 | 06:38 PM
  #32
20gmr's Avatar
Originally Posted by C130flyer
I hope that is a joke......
EVOS DO NOT CRANK WALK AND EVOS HAVE PULL STYLE CLUTCHES unless you buy the AMS push style clutch upgrade kit.
your money is mine
I have seen two do it. We shall see who gets the money when the problem is solved.
Old Mar 27, 2010 | 07:58 PM
  #33
coastevo's Avatar
I did a boost leak test today with my little ghetto home depot made tester and it doesnt seem to have any major leaks.. Test ran like it has in the past.. I did read this thread that sounded interesting. http://forums.fourtitude.com/zerothr...int&id=4645011
Old Mar 27, 2010 | 08:02 PM
  #34
coastevo's Avatar
I do have an aftermarket intake... but it has ran perfectly fine tuned for it in the past.
This thread would suggest the possibility of knock and timing being pulled... Which I would know if I could get ECU-scan to work right.. Ill go try again.
http://www.turbododge.com/forums/f4/...r-go-very.html
Old Mar 27, 2010 | 08:17 PM
  #35
LGshow19's Avatar
oh i asked because i have a ETS intake and it hasnt been tuned for it... i have to give it a little throttle every time i start the car, and my AFRs flutcuate when it does get to idle.
Old Mar 27, 2010 | 08:19 PM
  #36
coastevo's Avatar
I think my lean idle during warm up is an open-loop problem.. and that would explain the stalling problem I had before raising my target idle (bandaid on a broken arm) out going into a stop in neutral and with the clutch pulled..
check this out.... this sounds exactly like my lean idle warm up issue http://www.hptuners.com/forum/showthread.php?t=8036
Old Mar 27, 2010 | 08:23 PM
  #37
LGshow19's Avatar
yea, i had the same problem with rolling to a stop.
Old Mar 30, 2010 | 03:17 PM
  #38
coastevo's Avatar
The rest of my problem is definitley solely a BOOST oriented problem.. I lean out in any boost. As soon as the needle gets past sea level (0), I lean out.. I can be at any rpm as long as I'm not on the throttle enough to make boost pressure and I don't have any issues.
Old Mar 30, 2010 | 03:19 PM
  #39
LGshow19's Avatar
do u have "lean spool' enabled?
Old Mar 31, 2010 | 10:08 AM
  #40
coastevo's Avatar
Ill check today after work.. What if I do/don't?
Old Mar 31, 2010 | 11:36 AM
  #41
LGshow19's Avatar
Well if you have it enabled that can cause sporatic AFRs during WOT...
Old Apr 27, 2010 | 09:47 PM
  #42
sal03evo's Avatar
i fixed my problem by changin the iac idle air control valve the old one looked fine they said but once they changed it out car ran like a champ back to normal finally
Old Apr 28, 2010 | 09:08 PM
  #43
coastevo's Avatar
What all were the symptoms you were having from the bad IAC?
Old Apr 28, 2010 | 09:50 PM
  #44
VRSF Tiago's Avatar
What intake do you have on the car?
Old May 22, 2010 | 09:19 AM
  #45
eusgen's Avatar
Did you solve this issue? what did you do to fix it?
My 02 Lancer OZ Rally has similar issues with stalling in nuetral from electrical problems. The check engine light just came on the other night after turning down a road and putting the car into neutral. I have a large amplifier and subwoofer draining power from the car faster than it can recharge, it will stall my car if I leave it on for too long. I am thinking about upgrading my battery and or alternator.
