School me on spark plugs
Old Feb 28, 2010 | 11:23 PM
2d-ink's Avatar
sorry for the thread jack. but I was always wondering about the E3 Diamond Fire spark plugs. anyone run those? how are they?
Old Feb 28, 2010 | 11:33 PM
wshihdnevo's Avatar
Like Freddie says just stick with the BPR7ES and gap them smaller. Depending on boost I would start at .024 and work your way to .020 and see how it goes. I have been gapping mine to .020 on 92 pump and 28 psi for quite some time and everything seems to be good.
Old Feb 28, 2010 | 11:37 PM
boostin350z's Avatar
ive been told that ams says to run nothing but oem plugs no matter how intense the build.
Old Mar 1, 2010 | 06:10 AM
Sim2k's Avatar
I've been reading up on this.. The best thing to do is simply read the existing plug in your engine, it will tell you whether it is too hot or too cold.
If you pull a plug and find a nice off-white or slightly tan/gray color with new-looking electrode shapes and no evidence of problems, you've got it right.
If you run 8's and find fouling, it suggests that your running a too-cold plug. This is the best of the worst situations, just go back to the stock 7's.
If the plug is burned white and has slight melting, you're running a too-hot plug, which is very bad. Running a plug that is too hot can put it in the pre-ignition zone, this is much worse than running a cold plug that will just foul over time. Go buy some 8's.
I've been running 8's on an Evo with minor modifications for about 6 months, I generally drive on open roads and do my best to avoid city driving. No fouling at all, so I'm sticking with mine.
Old Mar 1, 2010 | 06:16 AM
Fast_Freddie's Avatar
Veteran: Navy
How bout no...
Old Mar 3, 2010 | 01:49 PM
The Emperor's Avatar
what is the stock gap for the bpr7es?
Old Mar 3, 2010 | 05:59 PM
Veteran: Navy
Are you asking what it comes gapped to out of the box, or what you should gap it to?
Old Mar 3, 2010 | 06:22 PM
nothere's Avatar
I think generally you are better off with protruding electrodes. If your car won't let you then thats a different story. Getting the flame out in the chamber away from the boundary layer is a good thing.
Use heat range 7 unless you have some sort of monster motor. I love the idea that my motor needs an 8 but the plugs just don't show it.
26psi,valves,cams...
Old Mar 3, 2010 | 06:30 PM
nothere's Avatar
btw here is a thread about reading plugs that is a step beyond most of what is out there. ITs discussing carbed motors but...
http://www.innovatemotorsports.com/f...&postcount=102
gregivq
Lancer Engine Tech
43
Dec 2, 2018 09:23 AM
inshallah
Jul 5, 2016 07:52 AM
5LEEPERISAH23I
15
Sep 13, 2010 03:33 PM
gvillevo
12
May 25, 2010 09:32 PM
smokedmustang
10
Jun 5, 2005 09:04 AM
