Missing?
Old Feb 27, 2010 | 05:47 PM
b16_rex's Avatar
Missing?
Ok well i have an 2005 evo mr. I was going down the road the other day and it started missing at low rpms, then after driving a bit it stopped. The next day i went out and got new NGK spark plugs, on my way down to get them all of a sudden it started spuddering throughout the rpms. I put the new plugs in at the store trying to fix it no luck. so i drove it home doing like 20mph in 5th gear cause it caused it to lean out. Today when i woke up i started it up to work on it some more and it ran fine cold. so took it down the road to and once it warmed up it did it again. When your driving it and picking up it will all of a sudden pull like it fine and the go back to missing again, it will just flutuate from fine for a sec to missing and so on. Any body have any idea. BTW their is no maf sensor as it is running on autotronic ecu
Old Feb 27, 2010 | 06:03 PM
sktng22's Avatar
could be a messed up tune? fuel injectors? did u put iridium plugs in it? i put **** plugs in my car once and it sputtered like hell as soon as i hit boost
Old Feb 27, 2010 | 06:05 PM
mifesto's Avatar
what spark plugs you used? gap?
Old Feb 27, 2010 | 06:10 PM
b16_rex's Avatar
ngk bpr7es and there gaped to .24
Old Feb 27, 2010 | 06:14 PM
gsrboi80's Avatar
Fueling issue. Check your Fuel Pressure
Old Feb 27, 2010 | 06:18 PM
b16_rex's Avatar
will do, does anybody no how many ohms the injectors should be putting out. im use to hondas so what kinda fuel pressure for an evo
Old Feb 27, 2010 | 09:11 PM
b16_rex's Avatar
just wondering it doesnt sound like it is internal or like bottom end or head or anything does it. i plan to do a compression test tom but i dont wanna run it to warm it up if people think it could be internal. What kinda compression should evos have on a tester, cold or warm
Old Feb 28, 2010 | 02:19 AM
b16_rex's Avatar
bump
Old Feb 28, 2010 | 04:30 AM
b16_rex's Avatar
just so everyone knows that wants to help solve this delema im having i did a compression test on the car this morning and the virdict is 180/175/175/175 give or take a psi or two. so reading on here it doesnt sound like a internal problem.
Old Feb 28, 2010 | 06:20 AM
gsrboi80's Avatar
I don't have the FSM on this computer but i'm pretty sure Base FP is 43.5 psi.
Old Feb 28, 2010 | 01:53 PM
b16_rex's Avatar
bump need help here!
Old Feb 28, 2010 | 01:57 PM
think0rz's Avatar
sounds like a fuel problem
Old Feb 28, 2010 | 02:18 PM
b16_rex's Avatar
Old Feb 28, 2010 | 09:34 PM
barneyb's Avatar
If the car has over 60K I'd suspect plug wires.
Old Feb 28, 2010 | 10:00 PM
andrewzaragoza's Avatar
is this a typo? it should be .024
