Seafoam'd my Evo
Old Apr 29, 2010 | 05:52 PM
  #46
TommiM's Avatar
isnt it cheaper, and just as effective, to mix in a gallon of e-85 when you fill up the tank?
Old Apr 30, 2010 | 11:53 AM
  #47
SeeCoryRun's Avatar
Adding to the oil, sucking into the intake, and adding to the fuel tank achieve totally different outcomes....
-adding to the oil is meant to loosen and remove sludge. as it was said earlier, running and consistently changing with synthetic oil, there really is no need.
-pulling into the intake via a vacuum line cleans the cylinders of carbon buildup.
-adding to the fuel tank cleans injectors and cylinders.
my .02, i wouldn't feel good about doing this to a turbo car for the reasoning of possible detonation and extreme cylinder temperatures resulting from burning solvents.
Old Sep 9, 2010 | 10:28 PM
  #48
TheBoz's Avatar
One of the first things I dont on every used car I buy is 1 can of seafoam in the gas tank. I have never done the other methods.
I found that on High Mileage cars 100k+ it helps to smooth out the idle and general low throttle conditions.
I just put a can in the Evo tonight. The car does feel like it is starting to idle better, however I will wait a few weeks before I claim that seafoam is magic.
Also my brother ran some of this through is STI and had similar results.
Old Oct 12, 2010 | 08:00 PM
  #49
mobilman's Avatar
http://www.youtube.com/watch?v=mgTG6...eature=related
THIS IS NOT ME OR MY CAR, just found it on YouTube..
Old Oct 12, 2010 | 08:02 PM
  #50
dsmftw's Avatar
ive always heard about this but never new if it truly worked or if it effects the car in a bad way?
Old Oct 12, 2010 | 08:12 PM
  #51
bvasquez12's Avatar
i used it on my oz lol, and didnt change the oil for a week. gas mileage was terrible but once i changed the oil it was smooth sailing.
Old Oct 12, 2010 | 09:52 PM
  #52
nightwalker's Avatar
I've used it for years too. My Evo has already seen two applications. Pour a third into the gas tank, a third into the oil, and suck a third through a vacuum line.
When sucking through the vacuum line let it take the last amount and then turn the engine off. Let set for about five minutes, then start and drive around slowly for about 15 minutes. Immediately change the oil. Don't boost until a new tank of gas. Works great!
Old Oct 13, 2010 | 12:20 PM
  #53
teribble's Avatar
How would this act with E85?
Old Oct 27, 2010 | 11:18 PM
  #54
4bangers's Avatar
which vacuum hose do you use to suck in the 1/3 of the bottle? BOV or brake booster?
also if we let the car sit after suck it through the vacuum doesn't it hydrolock the car? because I read somewhere that a guy got it hydrolock by turn off the engine and let it sit.
Do you put 1/3 to a full tank of gas or half?
Old Oct 31, 2010 | 08:20 PM
  #55
4bangers's Avatar
will it damage the turbo seal? help....
Old Oct 31, 2010 | 08:29 PM
  #56
xRoguex's Avatar
No need to do it if your an e85 car...
Have you ever seen the inside of a well tuned e85 car?!
Addex
Jun 1, 2017 12:19 PM
N8vEvoVIII
May 2, 2016 05:44 PM
Messidona
Nov 3, 2008 07:03 AM
dxbevo9
Dec 8, 2006 09:06 AM
