Benefits of a Flywheel?
Old Mar 8, 2010 | 09:04 AM
evremonde's Avatar
like others have said, it will reduced rotating mass, thus generally improving acceleration/deceleration. A lighter flywheel will not dampen the crank motion as much, which can cause a rough idle.
Depending on your skill level and the weight of the new flywheel, it could improve shifting or make it more difficult.
An engine that revs a bit quicker will be easier to rev match, in my opinion. If it revs too fast, you might need to shift quicker.
Old Mar 8, 2010 | 09:05 AM
Q15H's Avatar
The main benefit to a flywheel is you will have something to bolt the crankshaft to on one side and your clutch to the other side.
Old Mar 8, 2010 | 09:47 AM
n2oiroc's Avatar
Originally Posted by [I.R.A.]_FBi
y?
Off idle power feels much weaker.
Old Mar 8, 2010 | 06:20 PM
awd2gen's Avatar
Originally Posted by neonglh
It all depends on the setup. I prefer my insanely light exedy triple setup, but I can drive cars with heavy flywheels just as well.
p.s. I've never heard of a stock flywheel exploding *laughs*
Really??? ever gone to the track?? This would be why a scatter shield is required on cars running faster than 12.99
I have witnessed first hand it happening on a friends car. Flywheel exploded cut through almost everything in the engine bay and only reason it didnt go through the firewall was because it hit a decent size bolt. You could see the indentation in the head of the bolt. People have been killed by this. stock flywheel is pretty heavy and spinning at some times 9k rpm..do the math = a ton of damage.
It literally took 15 minutes to pull the motor because everything was cut to pieces and destroyed.
Old Mar 8, 2010 | 06:28 PM
FooM Anchoo's Avatar
if it only took 15 minutes to pull it, i'd say it would have fallen out in 20
Old Mar 8, 2010 | 06:31 PM
awd2gen's Avatar
you aren't kidding. it killed a 35r while it was at it too.
Old Mar 8, 2010 | 06:32 PM
n2oiroc's Avatar
the only time i have heard of that happening is after someone "lightened" a stock one.
Old Mar 8, 2010 | 09:35 PM
JFuego777's Avatar
It happens even in the non racing world...can't say I've seen it on an evo, but I've seen flywheels break all around the mounting bolts...could imagine if this happened at high rpm... the result would be shrapnel.
RS200Z
Mitsubishi TC-SST Discussion
19
May 26, 2020 11:30 AM
JGNERAEVO9
Apr 9, 2015 01:02 AM
Evo_Jay
Sep 11, 2009 03:05 PM
futurevowner
Lancer Tranny/Drivetrain Tech
28
Feb 15, 2008 11:52 AM
Tha Shocker!
24
Oct 2, 2007 10:01 PM
