breaking up at 31lbs....plugs?
Old Mar 7, 2010 | 07:15 PM
xcelr8's Avatar
my car is breaking up a little on fp red at about 31lbs peak boost. at first it wasnt. should gap my plugs tighter? I had them at .026 with sparktech non cdi coils. Getting ready for the track and I dont want to get kicked out and not get a good run in. Any thoughts?
Old Mar 7, 2010 | 07:32 PM
Chele's Avatar
I run mine at .024 at 31lbs of boost on my HTA35 with no break ups.
Old Mar 7, 2010 | 07:34 PM
evoforlife's Avatar
when i had a boost leak on my car with the sparktech non cdi it was breaking up then i fixed the boost leak and never did it again hope this helps you out, if you have egr and the stock intake manifold still check all those crazy boost hoses going from the egr to the sensors and throttle body
Old Mar 7, 2010 | 07:37 PM
xcelr8's Avatar
have you ever gapped them further apart? the first few times out with the car it ran real strong. today and yest it broke up a little. do you have an ignition upgrade? I have 2 step colder plugs
Old Mar 7, 2010 | 08:02 PM
partyboy1122's Avatar
Boost leak or re-gap. Try .020
Old Mar 7, 2010 | 08:17 PM
xcelr8's Avatar
no leak. it was fixed. ill try regapping
Sandroc
May 25, 2011 03:05 PM
CtSilver03Evo
May 2, 2011 07:14 AM
Gump
Evo X Dyno Results
129
Nov 4, 2010 01:27 PM
Nismo2evoawd
Jan 30, 2010 05:22 PM
Johnboy1065
Mar 18, 2008 03:02 PM
