questions about boost. Please look at my log
Old Mar 18, 2008 | 01:17 AM
Johnboy1065's Avatar
I have the car tuned for 31 lbs of boost. I realize I'm only hitting a maximum of 29.282 lbs of boost at 23.86 seconds on this log at 43 degrees outside temperature. BUT it only peaks at that boost level then quickly goes down to around 27 . my question to ya'll is are you supposed to set your boost by the Peak or by what your car consistantly holds???
I realize I'm obviously not at 31 lbs of boost yet but I have it around this boost level so that I wont overboost if it gets cold outside. but the track day is coming up and I was just wondering if I should set my boost where it PEAKS at 31 lbs or holds consistant at 31 lbs???
I hate doing logs like these but I just want to set the boost to as perfect as it can be for the track.
File Type: txt
Old Mar 18, 2008 | 06:38 AM
EvoDom's Avatar
my evo was tuned for 24 lbs of boost and it spikes 24 and holds around 22. i gues its tuned for the peak.
if that info helps
goodday brotha!
Old Mar 18, 2008 | 06:46 AM
Mr. Evo IX's Avatar
Yes, generally if someone says they are running 25psi then that is the spike, not what it holds at.
Old Mar 18, 2008 | 02:22 PM
if that info helps
goodday brotha!
ok cool. thanks for ya'lls input. I appreciate it
Old Mar 18, 2008 | 02:50 PM
DS-03evo's Avatar
Is this a 35r log?
Old Mar 18, 2008 | 02:54 PM
Originally Posted by DS-03evo
Is this a 35r log?
yeah it is. AMS gt35r with their 2.3 liter.
Old Mar 18, 2008 | 02:57 PM
DS-03evo's Avatar
So does the log go 1st-2nd-3rd-4th gear?
Old Mar 18, 2008 | 03:00 PM
also do ya'll think it looks a little lean in the 18.140-18.580 second range of the log???
Old Mar 18, 2008 | 03:02 PM
yes. I was granny shifting though just cuz I'm paranoid lol didnt go all the way through 4th either.
David Buschur
Feb 3, 2009 04:22 AM
phabaznbro
19
Mar 3, 2008 07:15 PM
BEN06'
17
May 20, 2007 05:20 PM
EvoBroMA
Apr 5, 2007 09:15 AM
evolutionist
Sep 20, 2003 05:01 AM
