Advertised Duration for Comp 272 Cams???
Old Mar 10, 2010 | 12:27 PM
PsychDr. HN$'s Avatar
Lightbulb Advertised Duration for Comp 272 Cams???
Hey I just picked up a used set of Comp 272 cams. I looked at the cam thread and I saw where it stated that the advertised duration is 256/257. I thought the advertised duration would be exactly/approx 272 since theyre "272" cams??? Lift is 10.8/10.2 which is about right for a 272. Im satisfied eitherway because theyre better than my stockers and I got a pretty good price on them. Eventually, I will go with a more aggressive cam much later down the road when I go with a larger turbo but for now Im good.
Can anyone shed some light on the advertised duration?
Does this mean that its a "weak" cam compared to other mid level 272's?
*Im hoping that they are a step above HKS 272 and Im thinking they are below FP4R's.
Old Mar 10, 2010 | 12:32 PM
Kracka's Avatar
Looks like you have the Comp "272+" cams. I think they're trying to compare themselves against the other 272 grinds on the market, but must measure advertised duration in a different manner. You're right in thinking they're between the HKS 272's and FP4R's.
http://www.compcams.com/technical/Ca...106-07/224.pdf
According to my math the intake lift is 11.0mm and exhaust lift is 10.4mm.
Old Mar 10, 2010 | 12:44 PM
Sounds good. Btw, I like your math! . I will be happy If I pick up at least 20whp with them. We will see soon.
doghouse
19
Mar 26, 2015 01:47 PM
David Buschur
18
Mar 17, 2012 10:32 PM
kaj
18
May 7, 2010 08:45 PM
JC evo1
54
Oct 12, 2009 07:59 PM
erioshi
101
Oct 24, 2007 05:04 AM
