Upgrading / Reinforcing the 6 speed
Old Jul 8, 2010 | 06:28 AM
  #181
veszett's Avatar
got an email from john the other day and he said testing at 640hp, no he didn't mention tq, is complete so the gears or at least the pricing will be released soon.
bit late for me atm, getting a new clutch fitted monday...lets wait and see pricing.
4.09 fd would be pretty cool too.
Old Jul 8, 2010 | 06:45 AM
  #182
metalsaber's Avatar
Well 640 is plenty of room. I'd never get that close. Hopefully we can get a price and possible release date.
Fingers crossed.
Old Jul 8, 2010 | 08:48 AM
  #183
rgonyer's Avatar
I want.
Old Jul 8, 2010 | 08:52 AM
  #184
andrewzaragoza's Avatar
it would be nice to see the torque of the car that it was tested on.
Old Jul 8, 2010 | 09:26 AM
  #185
JohnBradley's Avatar
I posted it in here before, but we have seen at least 3 6 speeds shear 6th in extended pulls.
Old Jul 8, 2010 | 09:38 AM
  #186
Erik@MIL.SPEC's Avatar
And this upgrade is only for 3, 4, 5...so if you're looking to do high-end highway pulls, you may want to stick with the 5 speed...or get your 6th gear WPC treated.
Old Jul 8, 2010 | 12:08 PM
  #187
5th tops out around 145 at 8200 (stock), so it needs something past that if it were on a fast "closed" course. changing the FD at the same time might alleviate that enough to make it all work together well. I keep forgetting the FD change.
Old Jul 8, 2010 | 12:16 PM
  #188
What does that come out to with the new FD (like a 4.11 or 4.09)?
Old Jul 8, 2010 | 12:33 PM
  #189
Well I had only been going on memory, it appears that 8200 in 5th with a 245/45-17 should be 165 and switching to the 4.09 brings it 186. 6th would cruise at 2600 or so at 70 so not too shabby.
I stand corrected.
Old Jul 8, 2010 | 12:48 PM
  #190
metalsaber's Avatar
I stand corrected.
2600rpms around 70mph? Count me in. Stock around 70mph is around 3000rpms.
Old Jul 8, 2010 | 12:57 PM
  #191
mrfred's Avatar
170 mph at 8200 rpm in 5th gear with 4.09 final drive and stock diameter tires.
Old Jul 8, 2010 | 02:56 PM
  #192
Yeah, well, um, that's plenty fast enough for me.
Old Jul 8, 2010 | 03:08 PM
  #193
Teal2nnr's Avatar
Based on what?
Base on the size limitations of the housing. Thicker gears stronger? or is thing incorrect
Well all know the 1-3 are thinker on the 6 speed.....this is not the issues. Its 4 + that **** the bed, and its a given that the 6 speed housing is the same size as the 5 speed therefor you're not able to get the same width in the upper gears...were the issues arise.
I think its great that shep is investing time into research on strengthening the 6 spd....But swapping to a Five speed isn't rocket science....and i see nothing but benefits with going to it.
You may have an alternative view and thats fine. Thats just the way i look at it
Old Jul 8, 2010 | 03:19 PM
  #194
Well, until we have data this is all supposition. You were stating that the 6 speed would "never be as strong" as the 5 speed, which is where I had a problem with what you said.
I am no engineer, but the new upgraded gears look to have much more material there...so the potential exists it could even be stronger than the OEM 5 speed gears. You saw the pics of the new gears, correct?
Old Jul 8, 2010 | 03:44 PM
  #195
Teal2nnr's Avatar
I must not have read through your original post thero enough....I was talking about a build 5speed vs a build 6 speed. I will agree that this new gear set would (from my understanding) be stronger then OEM 5 speed gears.
