Front Diff
Old Nov 13, 2003 | 12:37 AM
  #31
leaveit2bevo1's Avatar
In Timeout
I know one guy who runs a gt40 and a crazy grabby *** clutch and I thought he would kill his diffs to but somehow amazingly they hold up he also said that either rnr or rmr runs the stock diffs on there rally cars so they must hold up.
Old Nov 13, 2003 | 04:28 AM
  #32
jemm's Avatar
Originally posted by JT-KGY
??? still not clear...
Where's the front differential? in the transfer case or
transaxle?
Also, how do one know if the front diff is gone?
What are the known symptons?
Hi JT, here is something that might help:
Old Nov 13, 2003 | 04:31 AM
  #33
jemm's Avatar
Usdm tranny/transfer/diffs:
1. 4th gear
2. 3rd - 4th synchronizer
3. 3rd gear
4. Transmission case
5. Clutch housing
6. Clutch release bearing retainer
7. Input shaft
8. Output shaft
9. Front differential
10. Viscous coupling unit (VCU)
11. Transfer cover
12. Hypoid pinion
13. Center differential
14. 1st gear
15. 1st - 2nd synchronizer
16. 2nd gear
17. 5th gear
18. 5th - reverse synchronizer
19. Reverse gear
20. Reverse idler gear
Old Nov 13, 2003 | 05:00 AM
  #34
CarPhoto.net's Avatar
Most dealerships will not warrenty your drivetrain if you have a different clutch. Techs claim it can rip out the drive train.
Old Nov 13, 2003 | 08:16 AM
  #35
AMS's Avatar
AMS
transaxle?
the front diff is in the transfer case, the center diff is in the transmission.
Martin
Old Nov 13, 2003 | 11:45 AM
  #36
JT-KGY's Avatar
Thanks jemm & AMS... !!
So it seems like switch open front diff to EVO RS's front LSD would
be easier by just changing out the transfer case then?
TIA,
Old Nov 30, 2003 | 05:20 AM
  #37
ubadynnam's Avatar
Marcus,
I have access on getting a transfer cases for Evo 4-7s. The Evo 8 is fairly new and parts are expensive. The Evo 7 CT9A is the same as the 8. How much are you willing to pay on double shipping from Japan. I get it delivered to me and I send it to you. Hopefully the item is not over 70 lbs or else I can't ship it. The items are used items. If you are interested, let me know and I will see the availabilities of the items.
One separate note to everyone, how easy is it to remove the transfer case from the gear box? I am having a hard time removing mine (Evo4). It seems to be caught on some thing and it does not easily slips out of the gear box. I did remove all six 17mm bolts and CV shafts. Help anyone?
Thanks,
Manny
Old Nov 30, 2003 | 06:05 AM
  #38
gaz@cpp's Avatar
Manny you will need a slide hammer to pull out the shaft from inside the transfer box and also the shaft from inside the gearbox. The shafts im talking about are the ones which your drive shafts go onto. Once you have removed them your transfer box will come off.
gary
Old Nov 30, 2003 | 06:07 AM
  #39
gaz@cpp's Avatar
ps manny can you get hold of s,h, E6 rs rear diff's ?
Old Nov 30, 2003 | 06:17 AM
  #40
Please understand many parts can break during a launch.
It is possible to do damage thats spikes based on high engine RPM and shatter parts during a launch.
This is not because of the EVO. This is launching or heavy driving.
Old Nov 30, 2003 | 12:13 PM
  #41
stock_evo's Avatar
Guys, sorry i am a newbie....
my evo has this problem recently....3 ACD light up at the same time(happen once 2 days back) and return to normal after i restart my engine. now i encounter another problem after i turn my key to ignition(before i crank my engine), by right 3 ACD will light oni for around 1.5 seconds and return to normal state but now 3 lights lighted up together and stay there until i start my engine then only it return to normal state(e.g tarmac).
My transfer gone case?????
Old Nov 30, 2003 | 08:19 PM
  #42
jemm's Avatar
Heya, your AWD (ACD + AYC) Ecu is reporting a fault. Try this first...
1. Make sure you have not overfilled or underfilled your Transfer case with oil recently.
2. Disconnect the battery overnight to clear out the ecu.
If the 3 lights come on again..... take it to the dealer and have them connect the Mut-II diagnostic computer to your car... that will tell them where in the system the fault lies.
Old Nov 30, 2003 | 08:23 PM
  #43
Chris in HB's Avatar
I swear - I nominate Jemm as my Evo guru
Thanks again for the info - helpful, as usual.
Old Nov 30, 2003 | 08:26 PM
  #44
jemm's Avatar
thanks Chris, but i have so much more to learn. These forums have help a great deal in this regard... evom.net rocks!
Old Dec 1, 2003 | 01:29 AM
  #45
ubadynnam's Avatar
Thanks for the info. The rear diff, I will see if any available. Can you specify s,h,E6 rs rear diff's as Stock, ??, Evo6 RS rear diff? Not really sure. Also, where is your location? Shipping may be a snag.
