Definitive EVO8 vs EVO9 Turbo Specs
Old Mar 13, 2010 | 04:56 AM
bigwig's Avatar
I'll first mention that I've searched, read the sticky, and done a fair bit of research. The reason I'm here is because I'm piecing a kit together for a different car. I've seen the EVO8 and EVO9 turbo used on a few DIY setups and the results have always been favorable, especially on smaller engines. They are very efficient turbos, but are turbine limited.
With the thread stickied above being a bit dated, I'm hoping someone will be willing to share a what might be considered common knowledge at this point. I'm trying to decide if the $200-300 difference in price is enough for me to care. As much as personal opinions and experience matters, I'm really looking for raw technical data.
Specs I'm looking for:
Turbine Wheel Measurement(s) (Inducer and Exducer)
Compressor Wheel Measurement(s) (Inducer and Exducer)
Turbine Housing Measurements/Specs
Compressor Housing Measurement/Specs
Compressor Flow Map
Relevant technical commentary(Material choice, design notes, ect)
Thanks in advanced for your help
Old Mar 13, 2010 | 10:13 AM
itsme4g63's Avatar
10% larger compressor housing and wheel, 10.5 hotside stock nuff said
the magnesium part only applies to certain models like the jdm spec evo 9 gt
theres no reason not to use a evo 9 turbo unless you already have a evo 8 lying around
Old Mar 13, 2010 | 11:27 PM
bigwig's Avatar
Thanks for that information. It is helpful.
I'm still very interested in raw technical information though.
Old Mar 14, 2010 | 05:57 AM
codgi's Avatar
The 05 Evo VIII turbo's came with the 10.5 hotside stock....
Old Mar 18, 2010 | 10:44 AM
JFuego777's Avatar
Edited: removed after realizing I'm a dumbass. nuff said.
Roen
Mar 14, 2015 10:55 AM
DragonDog
Mar 22, 2012 07:32 PM
hydra
30
Nov 23, 2011 02:02 PM
3gEclipseTurbo
38
Nov 14, 2009 06:12 PM
Carloverx
15
Aug 5, 2009 04:20 PM
